- Dec 9, 2000
Please explain your point.
If you missed the obvious he is saying its also faster at 1080p and that he took your point as this card is only good at high resolutions and loses at 1080p
Your cpu is holding you back not your gpus.
all the GPU power in the world is not going to get him 120 fps maintained with his CPU in most gamesAll sites tested the 290x Titan and 780 with Crysis 3 in FXAA VERY HIGH @1080p which is garbage setting to me and that my opinion btw , and most these cards where getting crippled under 50 fps.Now with a WC Titan 1176 mhz I was able to do 2 X MSAA Ultra
at 52 fps. So is the 290x to much for 1080p Hell no if you like the best settings let alone you'll need crossfire to maybe hit 120hz . 1080P is still a contending resolution to deal with unless your running game's with consoles engine's
I would just get a to a 280 X.and a TV at 120 Hz is not going to allow you to really see more than 60 FPS anyway since its input will only be 60.280 X just makes more sense for you.
the odds of him picking one of those models is pretty smallYou would be wrong. There are quite a few "3D" enabled LCD TVs that can do 120hz in 2D..Go check out AVS forum since I know you are going to come back and deny I am right..
As far as "overkill" @ 1080P, for the insane performance you get $549, I would say go for it OP..If you are comfortable spending $549 on a GPU that rivals Nvidia's $1K GPU, then buy it and enjoy yourself. You can smile with glee as you slide those quality options all the way to the right, at ULTRA..
Then your best bet is to get a 290 non X. The 290x is overkill for 1080p.
Hell even a 280x would fit your needs.
If price isnt an issue you can get a 770, but get the 4gb version.
Eitherway a 290/290x is overkill for 1080p IMO.
so would a 670 vanilla with medium high settings @ 1080pWhat a load of rubbish. The 290x would be a great card for 1080p @ 120fps/hz
hey even my dinky 660ti can play any game I have at 60fps on high settings or better. lol no need for medium even with it.
