Thanks. I am running the stock ASus BIOS ok at 1200ish/1600 but I need 1.412v to push it. That is max voltage. My temps are ok. I tried the PT3 BIOS and it was very unstable at any speed. Going to try the PT1.
How much voltage you use for your benchmark?
Yeah I also tried PT3 and its really bad, I got black screen every 2 seconds on desktop when using that with no additional voltage whatsoever.
My bench volts were 1.437 set with GPU Tweak so real voltage was more like 1.32 or something like that. Black screens start to haunt after 1.3ghz or if upping voltage even a little bit more. And I don't even have visible artifacts with those clocks so I'm a sad panda atm
