Well im buying a 2900xt*giving ati one last chance*. But my new computer psu only has a 500watt psu. So I was thinking to get this http://www.newegg.com/Product/Product.aspx?Item=N82E16817153037 Is 250watt enough for a 2900xt? Thanks.
In all honesty PC Power & Cooling Silencer 750 will do you goodjust get a new power supply. The termaltake in ur sig is advertised at 430 but in reality it chugs at 350. Best bet is to get a solid 550 watt PSU from a trusted vendor like Enermax, Seasonic and PCP&C.
Silverstone ST50EF-PLUS is only going to cost you an extra $30 or $40. Maybe. Or do you already have the Raidmax bought? And it isn't an 2900XT thing. This is a matter of having a good power supply you can count on.Ok fine I won't get a ati 2900xt, instead I will get a evga 8600gt and a ultra 550watt modular power supply and wait for the ati 2600xt to come out. Sounds like a plan?![]()
As far as I know they don't actually make PSUs at all and use multiple suppliers. So you are playing a parts lottery buying whatever was lowest bidder on a "bargin" PSU at that point. Thus their rather poor reputation is fairly earned.Is raidmax good at making power supplies?
250W? The card in total is going to draw less than that, and part of it's power comes via the PCI-e bus, so yah. I don't know much about running 2 separate PSUs though. Oh, and you don't actually need an 8-pin connector (even though your Silverstone would come with one, and Thermaltake will send you the correct one....I've heard that some Thermaltakes are shipping with the wrong 8-pin connector). Even if you want to OC you don't need the 8-pin as only the ATI tools themselves do that check, not 3rd party tools.But that thermaltake 250watt power supply for gpu is enough for a 2900xt right?
