[LYL]Homer
- Jun 7, 2004
I'm a late arrival, but here are my 2 cents - overclocking seems to be implied but not stated outright, and there's this:
Sounds like this is a gaming rig, and gigahertz counts over cores. Sounds like you're trying to get every little ounce of performance out this system, but if you set your goal 5% lower you could save 20%. Your call on this. I'm giving some budget allowances in some instances instead of specifics because there are multiple choices. I do this more to give you a reality check on your budget.
280 E6850
180 motherboard - diminishing returns above this budget allowance
40 HSF - Personally I find the stock HSF fine for 500mhz overclocks.
85 RAM
280 8800GT 512mb
50 case - a $25 (AR) Centurion 5 will run just as fast as a $110 (AR) case.
140 PSU - there are good psu's and there are also overpriced/overhyped ones.
170 Raptor 150 RAID 0 will fail, sorry, it's reality and it's just a matter of when
100 500gb storage drive
30 DVD burner
185 sound card, sounds like you're an audiophile and it's worth $100 premium
270 Logitech Z-5500, sounds like you're set on these
200 Vista Ultimate 64bit
60 shipping
$2070
I was shocked to read the title of the thread - that $2700 is needed to buy a gaming rig (minus monitor even), or even $2200. The audio system alone is at least $455, 64bit over 32bit adds about $30, 4gb ram vs. 2gb is about $50. I also think you could drop to a 600w SLI psu and be fine for $70 especially with 8800GT instead of GTS or GTX. Get really tight and you can find great $120 motherboards that overclock great too, but it might not have the latest chipset with all the features you don't need.
Overall this feels like a $1500 system that's bloated up $600 but maybe that's just me. And not to be too much of a downer, it'll be depreciating from the moment you order it!
Love,
Homer
What I mean is I don't want to spend an extra $100 on a product that I could get for less at no cost in performance.
280 E6850
85 RAM
280 8800GT 512mb
30 DVD burner
60 shipping
$2070
Love,
Homer
