There isn't a place to debate an AM4 or CL cpu?
I guess since I am on the fence, I will ask what AMD users or those who are contemplating an AM4 cpu think.
If the chips were the same price, which would you pick out of:
R7 2700X or i7-8700k? Will the upcoming AMD processors be compatible with the current AM4 socket out now?
I don't have a preference... I was mostly trying to compare power consumption and temperatures and they seem very close. Maybe the power consumption for the Ryzen chip is higher but the temps are a bit lower than the Intel (although, you can delid the Intel chip, right?).
I figure most games will favour the CL chip but the AMD cpu is sufficient for me regarding games. I don't have a problem if the FPS are a bit lower in some games.
The AMD chip is often higher in performance because of the extra cores? It does well in productivity tasks/apps.
I am undecided. I also like the Intel chip for other reasons but am not sure which to pick.
