Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
So how are you guys keeping your ppd up with these stupid units? They take many of my machines down to just shy of 3000 ppd and it has me wondering if I should drop bigadv?
[H]ard|DCer of the Month - March 2011/June 2013/De
if it knocks you down to 3k that means you can't meet the deadlines on 2684... what are your machine specs?
The cry is well known and old about bad point units... but stanford only listens to gpu whiners... so man up and build bigger beasts... 57:36 is the tpf cliff for 2684 ... 1 second longer per frame and no bonus...
no idea what my tpf is but I guess I will have to make sure everything is overclocked past 3.8. I need to get my sr2's built. I've been running bigadv for months cranking out tons of points until these 2684's and I am fine until I get those. Wish there was a way to avoid those ones.
Any ideas on what could be causing it? I guess I just need some more spare time to get everything water-cooled so I overclock more. Is bigadv working with Linux if so maybe I should convert a few machines to that. Just want to increase my ppd to at least what it was.
It just means you aren't making the deadlines so they don't give you any bonus points. You need to run linux or a VM, clock the computers higher, and/or switch to SMP. Also get your SR2 built right now. As far as water cooling you can get tons of cheap air coolers that will do the job. You can get loud coolers like the Frio or if you really like high end cooling you can get bigger quiet units like the Nocuta DH-14.
Folding1 has a Bloomfield running at 3.46ghz and manages to squeak under the deadline with a TPF of 51-52minutes. A 2684 will take around 3.7 days to complete at that clock speed. Most of us hate those things, but science still needs to be done even if it doesn't have the payout of other work units.
newbs, running linux on the dedicated machines will decrease your tpf by several minutes and should allow them to finish on time without changing clockspeed.
