NewBlackDak said:Most are hitting 2500 without issue. They start making alot of heat above about 2400, but I believe they're rated to take around 90C. Don't be too alarmed if they get up pretty high. I'm on water, and mine idles @45C, and hits 52C when it's been at full load for more than anm hour. Don't be disappointed if you don't hit 2600 though. I've got a second 2600+mobile that won't go over 2500 MHz even with 1.95v.
45 is plenty cool. My ol 300A was up around 70 sum. But we tourcherd that poor thingVisable-assassin said:damn and here I was bitching about my chip seeing 45c under load and that is 2.6ghz @ 1.975v LOL
felix88 said:my 35w mobile will do 2.6GHz but i need to use a tornado at full speed and i don't like the noise.
2.5GHz is pretty standard on the "XP-M" chips, but anything above that is going to involve luck and lots of airflow.
NewBlackDak said:Yeh, I think I've surpassed what this little Maze3 can handle. My water temp rise is barely noticeable, so I think the block is unable to remove the heat from the processor anymore.
Swat said:I think that topped with you live in TX. I'm sure your ambient temp is not as cool as we (me being from AZ) as we'd like it. I get around the same temps as you @ the same voltage. Though I have a maze4, but that seems to be the only different. I idle around 46 and hit 53 full load. Stupid summer heat![]()
rogue_jedi said:one of the newegg reviews for my chip has a guy with it at 200x15 on a machII so i'd say you'd have a decent chance of getting 3ghz with a machI. and yes you have to try![]()
You need to try the tic-tac D23-Fire2 bios. I've had no problem at all using the higher multi's with it.Visable-assassin said:...im may have to call BS on that guys claim...mobile bartons can only do 13.5 or 14 on the multi...unless hes some how modding the socket or chip itself...I know damn well I cant get no 15 multi on a mobile onmy NF7-S which will unlock pretty much any chip you throw in it...
NewBlackDak said:You need to try the tic-tac D23-Fire2 bios. I've had no problem at all using the higher multi's with it.
rogue_jedi said:any mobile chip is 5. the 15x none of the mobiles have access to multipliers above 12.5x on 4-bit encoded multiplier motherboards AFAIK. i could be wrong (correct me if i am too)
Cant speak for 4 bit but on the NF7-S the highest I can go is 13.5 any higher and it resets everything to 6x100...fun stuff 14x seems to hold sometimes then not...so I dunno what the hell is goin on
Try that BIOS I sent you. I just tried 15x133, and it worked fineVisable-assassin said:Cant speak for 4 bit but on the NF7-S the highest I can go is 13.5 any higher and it resets everything to 6x100...fun stuff14x seems to hold sometimes then not...so I dunno what the hell is goin on
NewBlackDak said:Try that BIOS I sent you. I just tried 15x133, and it worked fine
mcryptic said:i have a 2500+ mobile @ 2.4ghz with 1.81v core, its runs at around 123F under full load, if i put my case door it will goto 150F in about 30 minutes. I'm not that worried, my old tbird 1.33ghz ran at 125F for 3 years straight. I stopped upping it after i got it stable at 2.4ghz, its plently fast compared to my old computer.
God damn! That got to be like half the temp of a Prescott (LOL sorry couldn't resist)Visable-assassin said:holy bejesus man 150f !! on a mobile !
My 1.4 T-bird ahyja would do 1.6ghz @ 1.9v and on an alpha pal 8045 with 50cfm sunnon id never see above 125 under load on a normal day....the highest I ever saw was 130f...im glad I moved over to water LOL
CrimandEvil said:God damn! That got to be like half the temp of a Prescott (LOL sorry couldn't resist)
Seriously though you should look into WC that puppy, thats some scary temps.
What I run normally is in my sig, but I wanted to try the 15x to make sure I wasn't crazy.Visable-assassin said:When I get home bro
Im not running 133FSB tho...try 200mhz or above but when I get home Ill check it out![]()
Visable-assassin said:oh I dont see temps anywhere near that high any more my friend...thanx to this baby
NewBlackDak said:What I run normally is in my sig, but I wanted to try the 15x to make sure I wasn't crazy.
flak said:i'm jealous. i got the copper one. should be here tomorrow. w00t!
