Its good to hear one of AMD's promises fullfilled. I also like how some of them are low profile. Now the question is, can it do it better than Nvidia can?
Highly doubt. It is common knowledge in the HTPC crowd that PureVideo blows away AVIVO for picture quality.
Yeah, right. Nvidia always blows away ATi according to you![]()
I'm still trying to figure out any sort of relevence that it might have.What was on that site, besides the funny colors?
You know, that link you give doesn't really disprove what OM said nor does it prove him right either.
All it is is a discussion on what Avivo and Purevideo are; not "which is better." Hell, the one guy in there that actually does say that doesn't even know WTF he's talking about and the other guys call him on it.
Either way way I'm thinking of picking up a 2400 Pro to play around and see if it's worth replacing my 8500GT sitting in my HTPC. From the looks of it it seems that HTPC usage is pretty much the only thing where ATI shines with their new generation of cards, thats just pretty damn sad.
Clearly you have no idea what your talking about. Purevideo is considered the defacto standard when it comes to MPEG2 codecs; all others are compared to it.If you know what PureVideo is then you won't say that nVidia card has a better pic for HTPC.![]()
Now I know you're not fucking serious; to make an ignorant statement like that.If you know how to setup your HTPC correctly, you can get a great pic from any card as long as you have enough processing power.
Which governs the quality of the video as it's being decoded.It is just a codec![]()
LMAO Uh, no. If this is the crap that is being spewed around AVS Forum then I have no reason being there cause it's evident that AVS has devolved from a temple of media geekiness and knowledge to "noobs" who couldn't even properly configure their systems for DVD playback.Clearly you need to go to AVS forum...
Which governs the quality of the video as it's being decoded.![]()
Let me guess, Purevideo is "teh suxor" simple cause you have to pay for it, right?
Thats like saying it doesn't matter what video player you are using cause "it's just a video player" which is what makes you ignorant. Load any DVD in properly configured MPC, WMP and Zoomplayer and you'll get a video that is slightly different across all three apps. You could even be using the exact same DVD codec; it doesn't matter cause all three handle the rendering of the video differently. The same goes for MPEG2 codecs.
It's only FUD if it's not true.Believe what you want but please stop spreading FUD about nVidia's cards have a better picture quality for HTPC.![]()
Read my post again,It's only FUD if it's not true.You haven't even "proven" your assertion that NV cards are terrible for HTPC use. Look around to any HTPC site and they're been the standard for a while now.
ATI's current cards might change this though since it seems that HTPC use is their only worth.
I never said that nVidia's card is terrible for HTPC, I said that you can get a great pic from any card if you know what you are doing and it is better to have more processing power, which you can get with a card that has a better hardware acceleration.If you know what PureVideo is then you won't say that nVidia card has a better pic for HTPC.If you know how to setup your HTPC correctly, you can get a great pic from any card as long as you have enough processing power.
Thats usually what happens when someone brings some sort of bullshit in, I don't know what his beef was/is but he's totally wrong and I'm not terribly sure if he understands what exactly he's talking about. Either way:I dont know how this thread out of control
It's digital out just like if you were using SPDIF out. All it's doing is sending the audio data along with the video data through a single connection.Now I just need to know if the audio over HDMI is any good.
Clearly you have never used a codec that can be customized with post processing, if you have used such codec, you would know that you want hardware acceleration to gain more processing power. You don't need different player to get a slightly different video, you can use a same player and customize your codec to get a totally different video.
