- Oct 29, 2000
Hi all,
I'm planning an upgrade of one of my stepsons computers for the holidays.
I've read all about the TIM issue in Ivy Bridge and it has me a little bit concerned.
I know that IB has a small IPC increase over SB, but doesn't overclock as well due to the TIM issue.
So whats the best choice? A less overclockable 3570k with higher IPC or a more overclockable 2500k with lower IPC?
I have no desire to pry off the heat spreader.
Integrated graphics will not be used in this build.
I will be using a Corsair H80 for cooling.
Which would you pick and why?
Thanks,
Matt
Thanks,
Matt
