$2500 eyefinity build
The_Adm0n
Well, a cousin of mine asked me to put together an eyefinity rig for him. He works out of his house, and wants a nice work/gaming PC with lots of screen to replace his aging laptop.
He'll be mostly using it for work, although photography is a big hobby of his, so he'll be wanting to do some photo editing as well. He's a moderate PC gamer. Games I know he plays are WoW, Diablo 3, some all of the Total War games, and a bit of Battlefield 3.
$2,500 is the hard cap. Taxes and shipping included.
Kansas City, MO.
Needed parts:
CPU + cooler, GPU(s), RAM, PSU, SSD hard drive, optical drive(s), chassis, and a sound card if there's room in the budget.
Needed Peripherals:
Monitors, keyboard (he wants a mechanical one), speakers, headset for teh gamingz, and a webcam if there's room in the budget.
As far as the monitors are concerned, he would prefer a 16:10 aspect ratio, but might settle for 16:9 if the budget doesn't allow for it. 1080p or better is a must.
Regarding the optical drive. He wants to read Blu-Ray and burn CDs/DVDs. He already has a DVD burner, so a plain BR drive would probably be most cost effective, yes?
His mouse is sticking around. And he's got a 1TB Seagate that he'll be using for storage purposes. There's also a DVD burner that will make the port.
6) Will you be overclocking?
Yes, probably the CPU only.
7) 7) What is the max resolution of your monitor? What size is it?
1920x1200 is preferable, but 1920x1080 is acceptable. 20"-24" would be a good size. There's gonna be 3 of em, remember!
He'll be making the purchase within the next month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Crossfire and USB 3.0 - along with overclockability - are really the only must haves.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
He's got a legit copy of windows7 64bit.
Thanks in advance for the help! :)
CPU:
i5-3570k 230 dollars
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
GPU's:
2x XFX 7870 Ghz edition 640 dollars
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150605
Motherboard:
Asus P8Z77-V 190 dollars
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131820
PSU:
Corsair HX650 175
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
SSD:
Crucial M4 128 Gb 124 dollars
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442
Case:
Corsair 650D 119 dollars
http://www.tigerdirect.com/applicat...OCPFORM&cm_mmc_o=-KeCjCZ-qKR2VCjCqRmCjCdByAFF
Memory:
Corsair Vengeance 2x4gb 50 dollars
In my book gskill and corsair are equal, but this will fit the mobo better :D
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
CPU Cooler:
Corsair H100 115 dollars
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181017
And i believe your friend already has his optical drive and HDD
Monitors:
3x Dell U2312 Ultrasharp 750 dollars
Keyboard:
Razer Blackwidow Ultimate 100 dollars
http://www.newegg.com/Product/Product.aspx?Item=23-114-012
Speakers:
Pioneer Bookshelf Speakers 59 dollars
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405
Not the best, but great for the price.
Headset:
Corsair Vengeance 1500 70 Dollars
http://www.newegg.com/Product/Product.aspx?Item=N82E16826816005
Great Headset
This goes a little over 2500, but just buy when you can and it will drop below.
