250 MHz Max?
  • Thread starter Deleted member 143938
  • Start date
D
Guest
I was trying to follow the eclipseOC guide as my first OCing procedure.. I did
HT link multi = 3x
CPU multi = 5x
RAM divider = 100mhz 1:2
But after using Clockgen for a bit, it seems to crash at 250, which at the bottom of the guide it says if you can't go over 250 something is wrong. I tried changing my SATA from 1 to 4, didn't do anything, My PCIE seems to stay at 33, so thats ok, so I don't understand why it always crashes between 250 and 255.. anyone?
If you have a DFI LP UT Ultra-D then there is something wrong if you cant go over 250mhz because I have the same board and it goes well over 325
