As long as you observe the correct orienatation, it'll run fine. I ran a board almost a year just like this. Forget about the adapter, it's just another set of connections to go wrong.Bigga said:my friend just baught an A8R-MVP and his power supply has a 20pin mobo connection instead of the 24 pin... the 20 pin, however, does plug in but obviously 4 pins r left un connected... is it ok to run the system like this?
