Sony Windas,
Thanks for the info. I already ordered the cable, I hope you don't mind if I PM you once I received the interface unit. I already downloaded the software that is needed for the fix from the site I ordered from. It's the Windas software. Thanks.
No screen shaking here but I do have a *slightly* zoomed screen until it warms up. I bought a Sony G520P new in 2005 from newegg.com and its always had a bright warmup but the black levels become normal much faster than my FW900 (about 5 minutes vs. 15 on the FW900) The one weird thing about the G520P is the black levels have a red tint until it warms up.
Im curious why this bright warmup is so common in Sony PC CRTs but not with there standard CRT TV's or CRT HDTVs, I have 3 Sony TVs here and none of them suffer from slow / bright warmups (oldest model being a 27" Wega purchased in 2000)
emusicraft will sell the cable with windas if you request it (if not windas isnt hard to find) so you can do all the tweaking you want with their cable.
CRT Leak? lol.
It just has bad black-levels on startup... blacks look like greys for about 30-45 minutes... (Guessing)... and after that It's all good...
Hm yea if it were a crt leak issue then that means every sony pc crt Ive owned had this problem and most people in this thread as well ...which I seriously doubt..,even my ancient sony g400 has this symptom. Im still curious as to what causes the gradual increase in brightness on a lot of these monitors tho, This IS a problem since it eventually causes the screen to look totally washed out (even after warmup) until you lower the G2 level.
Well a lot of other old CRTs seemed to have a problem with getting darker and darker. My bet is Sony tried to design something into the logic to reduce that effect and totally screwed it up, causing it to compensate about 50 times faster than it should.
I dont think thats the case ...Contrast is what a CRT gradually loses over time and in these cases its Brightness thats gradually increasing. But for some reason Trinitrons do maintain there Contrast over time much longer than Shadow mask based CRTs.
Hi guys, i've got a rather large problem with my fw900. The other day i was playing bf1942 and all of a sudden the monitor turned itself off and the orange light started flashing, now its stuck that way and i can't turn it back on. I know this likely means the monitor is dead but i just thought i'd see if any of you fw900 experts might know if its fixable or not. Thanks for any info!
Ha! yes i've had a million and 1 problems with that game over the years, never expected it to kill a monitor though. Did yours die on a map switch or during play? Mine died RIGHT as a match finished and was switching maps.
This happens all the time to Sony CRTs which are suspectible to the brightness issue. Even ones that are not tweaked. It happens without any bright screen provocation on monitors where the brightness issue has advanced far enough.
It usually means the ABL_SHUTDOWN or some other diagnostic failure was triggered and the monitor doesn't want to turn back on. This has happened to me many times before. Hopefully, the same reason it happened to you is the same reason it happened to me.
Use windas to access the failures dialog precedures->failures.
Just checking the failures should clear them, consider using a lower DRIVE_MAX, a lower ABL_MAX, or a higher ABL_SHUTDOWN. ABL_SHUTDOWN is an X-ray protection measure for when the average brightness of the screen exceeds some value (such as, a high contrast max white screen, maybe a flash of a bomb going off in a game?).
Ofcourse, that advice asumes the failure was ABL related. It may have been another failure. The failures dialog sometimes falsely reports failures, so don't take it too seriously. The blinking light is a good sign, it usually blinks a code specified in the service manual (get a copy of this on the web).
Hope the problem was just an an ABL_SHUTDOWN trigger. Whatvere it was, you can atleast get it to turn on again via windas.
There are at least two other people who have been having this problem (I'm one of them). Others have described the problem on other CRTs. I noticed that this only happened within a few hours of turning on the monitor. So, the solution for me was to just leave the monitor on (turn off power saving and run a blank or mostly black screen saver like the default WinXP logo one). I believe the other person suffering from this problem had similar results and came to the same conclusion.The first one will suddenly start to loose focus and get fuzzy at random times. If I turn it off then back on, it is clear again but it may get fuzzy again a few minutes later. This does not happen all the time, but when it does it keeps repeating this many times in a row.
I think I recall reading in this thread somewhere that this can be fixed via Windas and is related to brightness or contrast being too high and tripping some safety value. I may be wrong, but I think you can raise the "safety value" threshold higher.The second one has very sharp text and has the better display, but its problem is that it will randomly shutoff. Pressing the power button off and then on again will bring it back to life, but it will usually shut down again after a few minutes.
Well I guess I'm #3 then. It happens to my monitor but only while its warming up... after the 1st 30 - 40min or so it doesn't happen anymore. The "popping" part worries me, it doesn't sound good and I hope it doesn't damage anything.There are at least two other people who have been having this problem (I'm one of them). Others have described the problem on other CRTs. I noticed that this only happened within a few hours of turning on the monitor. So, the solution for me was to just leave the monitor on (turn off power saving and run a blank or mostly black screen saver like the default WinXP logo one). I believe the other person suffering from this problem had similar results and came to the same conclusion.
Now it never happens. Unless I turn the monitor off for a few hours and let it cool down. One thing I've noticed though is that after several "pops" in and out of focus, my monitor will actually give a loud snapping/zapping sound and then pop into focus and stay that way. Though, I've seen it stop having trouble in less dramatic fashion as well.
I'm probably wrong since the FW900 is an entirely different monitor than what i've had...BUT.... from what i remember a "popping" noise often forshadowed the death of a CRT monitor, sometimes a monitor would pop for weeks and other times it would take many months. In other words i'd look into a fix before events play themselves out.Well I guess I'm #3 then. It happens to my monitor but only while its warming up... after the 1st 30 - 40min or so it doesn't happen anymore. The "popping" part worries me, it doesn't sound good and I hope it doesn't damage anything.
The ferrite cores are the way to go. I was also going to recommend something like a thick cable with ferrite cores on both tend to blargman.Ya, i can verify that there can be huge differences with different VGA cables running at high resolutions. A friend of mine once had a big box filled with every vga cable imaginable, and offered to give me as many as i would like. I then selected over a dozen different cables, ranging from 3ft to 6ft long, ramped my monitor rez up to 1920x1440, and began testing each one. Most cables fared well but 4 or 5 of them displayed artifacts ranging from ghosting, double vision, poor focus, blurry text etc etc. All cables were fine up to 1280x1024 btw, it's the higher resolutions that revealed their weakness.
It seemed the best cables overall in my test were the shorter, thicker, better insulated ones that had ferrites on both ends. One of the worst was a thin crappy 6ft dell vga cable.
Heh. That's not actually a bad price if it's the first owner and in pristine condition. I just recently paid $320. But then had to rent a friggin' SUV to haul the thing the 100 mile distance to my house. So, all told, I spent about $450 to get my "pristine spare."Bah, there's one local but he's asking $450...
Haha, not sure if I should go for it or not...
I think you might be confused.Why not just bust that one out and use that instead? They aren't going to last forever, so spoil yourself while you still can..![]()
We had hauled my first one in my wife's Jetta's trunk. Won't do that again! Had to squeeze it in and then I heard it rock a few times as we drove.
Now my heart doesn't skip a beat when my primary FW900 does something odd. Because I've got a pristine one in even better condition waiting in my closet.![]()
Question: I have an fw900. My current video card has 1 VGA and 1 DVI. Currently I'm just using the VGA.
However, I want to upgrade my video card to a 7600 gt. Those cards only have 2 dvi outs. I'm wondering how do I go about hooking up the monitor. I'm guessing I'd buy a DVI to VGA adapter. Do I want to go DVI -> VGA or DVI -> BNC? Would I want to buy an adapter or a cord? Are some higher quality than others? I don't want to loose any picture quality. Any quality cable brands would be appreciated. Has anyone had problems doing this? Thanks.
Isn't that kind of useless?
You're going digital to analog, - analog to digital.
The point of BNC is it's a digital input... no compression/loss of quality.
Honesty w/ the VGA mine looks great, I'll try a BNC if I ever find a high quality DVI - BNC cable...
No, you're going analog to analog. There is no conversion taking place. Nor should there be.Isn't that kind of useless?
Actually those little adapters are not too good at handling high resolutions, the symptoms are similar to a cheap vga cable, blurry text etc. A converter cable is definitely the way to go (least resistance).No, you're going analog to analog. There is no conversion taking place. Nor should there be.
A DVI-to-BNC cable is only theoretically superior because it eliminates the DVD-to-VGA adapter (which is not a converter, just a pin adapater). But, if you don't think BNC makes a difference, then certainly the resistance or impedence added by a single adapter will have no effect.![]()
Note my reply to Hurin above. Definitely get the adapter cable, and not the little adapter, seems many of them can't cut it for high resolutions. The DVI-to-VGA adapter cables are well proven so you might want one of those.Question: I have an fw900. My current video card has 1 VGA and 1 DVI. Currently I'm just using the VGA.
Retraction: The last DVI-A-->BNC-5 cable I received (from Blue Jeans Cable) does indeed work. A couple of the cables were in unfamiliar order (if not quite non-standard).
Instead of R-G-B-Blk-Gray, it was R-B-G-Gray-Blk. So, I had to swap not only the blue and green connector order when connecting the cable, but also the last two "synch" connectors. It now works perfectly.
Keeping this in mind, I highly recommend the DVI-to-BNC cable from Blue Jeans cable. It's super-thick and high quality.
I'm not sure if I can detect a difference between this and my old BNC cable. But removing that DVI-to-VGA adapter can't be a bad thing. If I had to guess, I'd say there's a slight improvement in clarity and text sharpness. But I wouldn't be able to swear to it.
H
