i recently bought a fw900 from unkle vito and i am happy with the picture on it however it has been showing alot of problems and i am afraid it might die
when i first started it it showed this (i had my dads iphone ready to capture the moment of the very first start)
http://speedy.sh/9558h/fw900.mp4
after that it has just been getting worse and worse here are a few problems
extremely blurry before warmup i know it's normal that it's blurry when starting cold but this one is so blurry you can't read text
weird focusing problem where the picture goes in and out for a moment
same weird flashes as shown in the video a few days ago it also also showes big uneven green lines in the picture (i have seen this problem before on an ibm monitor my dad used to have a friend said it is related to g2 voltage
this morning when i started it it flashed blue two or 3 times
all these problems only show when starting from cold it has never showed any issues when warm
then theres really bad convergence problems where windows and the edges of the screen is red or blue or anything i was told this is normal but is there any way to adjust it to make it less noticable?
i contacted vito about this and he says my electricity damaged it because europe/sweden uses a different type of voltage does that mean i can't use a fw900 in my country?
so my question is what should i do?
should i disconnect it and stop using it for now?
i don't even know whats wrong with it or what happpened with it it really makes me sad seeing how much i spent to get it here only to have it break down first start of it
i am trying to be calm about this but i don't know what to do
look at the back of the monitor where the power cable goes... how many volts does it say? 110 or 110-240 or 240?
