The LG and BenQ's don't use Samsung (from what I know).
If you're willing to spend an extra $200 planar has the same panel as the doublesight but in a more full featured package.The DS-263N seems like a budget monitor imo. Looks cheap and I'm sure it lacks features. It might be a great panel, but I'm not sure about the build quality.
10e: Of the somewhat available PVA monitors out there, would you say the LGs are the best? I've been considering the L246WP (if I can find one) and if its as fast as you say, I shouldn't have a problem gaming.
I'm trying my best to keep the price down lol. I originally started with a 22" Hanns-G that sucked. I decided I wanted to go larger and better quality. I think I've narrowed it down to either the LG246WP, FP241W, or DS-263N. The first 2 are a bit of a pain to find.
There's really no better monitor until the 24" NEC, but that might not be good for everyone gaming wise.
Unless you prefer a large screen size, but 26" already seems overwhelming to me.
BenQ FP241W and VW are pretty good. They suffer from a lot less than the two monitors you've mentioned.
Not quite as good as the LG L245/246WP which is usually under 30ms, but not too far off. They are around 20 to 30ms faster than the Dell and Samsung. Average on the FP241W is 33ms and the VW is about the same unless you turn on BFI (which is useless).
Regards,
10e
BB has the LG246 for $600. I wonder if it is any better than the Lg W2452T that I picked up on sale for $450. The dynamic contrast the latter is higher. The LG 26 inch is on sale at BB for $550 at this time.
