24" office use only
IWKUA
There are so many options I could use a little help narrowing it down. I'm looking for a 24" monitor for office use only for a friend. Input lag, ghosting etc are not that important. Most important is good viewing angles, even back lighting and clear good colors. I have a benq Fp241W that I really like, however it seems as if that model is being phased out and I assume there are newer better panels. Prince range is around $800. Thanks
If you can find an older Soyo, you could get all that for $300... the newer ones are turning into TN but anything made in and before November is MVA. I got one last week that was made in November so they still haven't cleared out older stock
http://www.officemax.com has them for $299 for the next couple weeks
hell dell has a deal right now for a complete pc and 24" lcd for 6xx something. Im sure that monitor more than fits the bill, and you could sell off the pc to make the monitor that much cheaper.
The BenQ is still around, and makes a great office monitor. It may not be around much longer, but it is still available in most markets.
Samsung 245T fits the criteria as well, as does the Doublesight DS-263N if you can get your hands on one (as it's in high demand). It's a 26" but also a fabulous monitor that fits your criteria extremely well.
Otherwise most new 24" panels coming out are TNs with worse viewing angles.
Regards,
10e
