I want to buy a 24" LCD in Europe.
After buying and returning a HP LP2475w due to dead pixels and other issues i am wondering if there maybe is a better display more suited to my needs.
I am sitting close to the display, around 50-60cm usually, viewing angle and backlight bleed are important issues.
It should have a non retina-burning minimum brightness, preferably well below 100 cd/m² to work comfortably at extended periods of time in a dark room.
I'd prefer it to have HDMI, Displayport and Component inputs but i suppose that could be solved using a input switcher or upscaler.
Built-in Pivot capability is also very important, though could also be solved using a wall mount and software.
It should excel at text rendering and video playback.
I'll likely try and give the HP LP2475w another shot when i find a hardware revision 133/143 F/W 68 model which hopefully resolves the issues i had with my GIG111/F/W 44 model.
I'm just wondering, are there other LCD's that size which fit the above criteria?
Eizo's S2431 and HD2442 seem interesting, NEC's Wuxi Series appears to fail due to the minimum brightness, and i'm not certain i want to spend an additional 500€ for their spectraview series just to unlock the hardware profiling.
Also am wondering if there may be new models close release worth waiting for.
Resources for announcements are also appreciated, But I do want to buy within the next three months.
Thanks for the input.
