24" 8-bit with HDMI
The title says it all. I'm looking for a 24" 1920 x 1200 monitor with 8-bit color, be it PVA or IPS, that has HDMI. And hopefully not horrendously expensive, or I'll just go with the Soyo and its DVI connection.
There's the LG L246WP or the identical LG L245WP, P-MVA. If you can still find one at Circuit City or Best Buy on closeout, you can get a very good deal for them, but more likely you'll have to go through an online reseller like Newegg, in which case it won't be nearly as cheap as the Soyo alas, but you didn't say what your price range is so I thought I'd at least throw it out as an option.
There is also the BenQ FP241W/VW, Dell 2408WFP, Samsung 245T, or Westinghouse L2410NM.
Regards,
10e
