No comparison. 2 x 2209WA no doubt. Unless physical monitor size appeals to you...
2209wa is probably the best bang for your buck monitor you can currently buy, and arguably one of the best gaming monitors out there. There is no comparison in the $200 per monitor price range imo.
But in return you get a crappy dime-a-dozen TN panel. Like I said, if a greater resolution and larger physical size is worth it for a degradation in picture quality, it's your choice.
