fightingfi
- Oct 9, 2008
Copied and Pasted from guru3d
For a couple of days now there is quite a lot of chatter on the web with GeForce RTX 2080 Ti buyers having issues, problems even running up-to the level where the card is bricked. We've monitored the chatter on the usual channels for a few days to see what is going on, and yeah the Geforce forums are flooded with reports.
The problems reported are rather diverse, some have unexpected BSODs, other cards just die and other show artifacts. All this does not seem to be related towards tweaking and overclocking. The thing with forum reports, however, is difficult, only people that have an actual issue will report it, the ones that are happy would not visit any forums, so as to what extent this is becoming a valid issue that is higher than normal RMA wise we cannot tell just yet. But something does seem to be going on.
If you dig around a little, several threads have been piling on Nvidia’s forum about problem RTX 2080 Ti cards for a while now. There literally are dozens if not hundreds of comments talking about crashes, blue screen of deaths, artifacts, and cards that fail to work or just die. It's not likely that all or any is related, but the number of reports is unusually high. By itself stumbling into issues a normal thing on support forums, however, what also is unusual is that the vast majority of reports seem to focus on the GeForce RTX 2080 Ti founder editions. There are some reports on Gigabyte and ASUS boards as well, but far less.
Since most GeForce RTX 2080 Ti owners will visit Guru3D.com, we'd love to hear from you. Whether that is a good or bad experience with the card, as I would like to see a more balanced view on the matter. Please do post your experiences in the thread below.
