2010 PC Olympics
Phimp
Every four to five years I piece together a new computer, this monumental event is known to me as The PC Olympics.
Last time I ended up with a 3700+ 2.2Ghz San Diego cpu, 2GB DDR400 PC3200 memory, nForce4 mobo, evga 7800gt, three 250GB WD HDD's in Raid-0, all thrown into a giant CM Stacker with Danger Den water cooling for the CPU with a 2x120 radiator.
it has had a good life but it now chugs along with some 1080p mkv bluray backups, and won't even attempt to play my 1080p video files from my camcorder.
The New Build:
I picked up a new TDX water block from DangerDen for AM3 chips with some new tubing/etc.
Threw another 2TB drive onto the order for my WHS Box and ended up just under $1K which was my aim.
I know I could have saved a few bucks here or there like $30 less for the 1075T instead of the 1090 but I figured for an extra thirty bucks, why not bump up, even if performance isn't that much of a difference.
The MSI 460GTX looks promising because I'm dB-conscious, so it being praised for it's quietness drew me in. (water blocks for a 460 are $$$)
Oh, also I'll be using my trusty old Antec TrueBlue 480w PSU but I suspect I may need to upgrade that soon, but not entire sure...
Any comments/suggestions to the order? Everything has already been ordered but if there's something horribly wrong I don't mind swapping it out with a return =p
Dangman
Ninja Editor SuperMod
Upgrade that PSU. It's too old and does not have enough amperage on the +12V rail to power your system for long. I recommend this as a budget upgrade:
$59 - Antec NEO ECO 520C 520W PSU
Also, for $5 more, you could have gotten a significantly faster SSD:
$145 - Crucial RealSSD C300 CTFDDAC064MAG-1G1 2.5" 64GB SSD
Phimp
If I were to budget $90-100 for a new PSU, what would be your recommendation?
I want to be able to potentially add another 460GTX, hard drives, etc.
I saw the Crucial C300 when I was pricing SSD's but was using AnandTech's benchmarks to compare my options; they seemed pretty evenly matched, with the Vertex 2 taking the lead in most tests. Although most of the benchmarks only include the larger versions of each drive but I am assuming that performance is somewhat similar between the different sized models in the same line-up.
But if it's actually a much faster drive then I'll order it and return the Vertex 2.
Thanks for the input thus far Danny, I always seem to trust other guys with the same first name as me =p
Edit:
How about the Antec EarthWatts EA650 for $70...
or the Antec NEO ECO 620C for $70 after a $15 MIR?
Dangman
I was basing my recommendation off this thread here:
http://hardforum.com/showthread.php?t=1564216
I would go with the Antec Neo Eco 620C since it actually has more power than the Earthwatts on the +12V rail despite the Earthwatts being rated higher wattage wise. Another good choice is the Corsair 650TX 650W PSU or the XFX 650W PSU (either one will work).
:D As do I man, as do I. :)
Phimp
I'm placing the order for the CORSAIR CMPSU-650TX right now.
I think I'll stick with the Vertex 2 for now and possibly pick up the Crucial C300 in a couple weeks & test em both out & use the lesser driver for my WHS box.
Thanks again for the input man!
