Team Obi Juan
Your Local Postmaster
- Sep 28, 2005
After showing my friend my setup, he wants one of his own. Though he is starting completely from scratch.
1) What will you be doing with this PC? Web browsing, streaming netflix, watching blu ray, MAYBE light gaming, watching TV, MAYBE some professional engineering programs (Catia).
2) What's your budget? $2000 shipped with tax.
3) Where do you live?Fort Worth, TX. Would prefer to use Newegg and/or Amazon. Probably best to pick up TV locally at Best Buy. Most large retailers are available, including Fry's, but no Microcenter.
4) What exact parts do you need for that budget? 46"+ 1080p HDTV, webcam, wireless kb/m, TV Tuner for OTA HD or cable (unsure how it works with cable boxes), blu ray burner and then literally everything else required for a computer. Aftermarket HSF if needed. Form factor of the case needs to either be an HTPC style case or perhaps a mITX case. Basically needs to fit in a standard media cabinet.
5) If reusing any parts, what parts will you be reusing? None
6) Will you be overclocking?No
7) What size monitor do you have and/or plan to have?46"+ 1080p HDTV
8) When do you plan on building/buying the PC?Within next 3 weeks
9) What features do you need in a motherboard? He has shown and interest in getting Wifi so he has the option to tether the PC to his 4G phone; I told him this is stupid and to just get internet. I think he just wants that option.
10) Do you already have a legit and reusable/transferable OS key/license? None. Need Windows 7 64 bit.
He moves into the new place in 2 weeks so we have not decided on the audio route. Space / ability to run wires might be an issues so I may end up just getting him a receiver and 2.0 bookshelves or floorstanding speakers. Else we'll go the HTIB route. But that also goes into the budget. Budget is semi-firm. Probably wouldn't take much arm twisting to go up $200 or so.
Preliminary shopping has me thinking $800-900 ish for the TV, <$800 on the PC, and the remainder on the audio. Currently he does not play games but if I'm building this, I think he should have the option. Doesn't need a badass video card but a modern one can't hurt plus HD audio passthrough is a must. I'm partial to AMD, but would go Intel if the $/performance is there within the budget.
Thanks for all help, I realize this is a big request.
