$2000+ Graphics/Modelling/Games/Movies
Niksa
Hi folks.
I'm looking to build a new system finally. I've got minimum 2000 to spend and I have a monitor, keyboard, mouse and I can buy Vista 64 bit through my university for a pittance. :cool: I am quite out of the loop with PC parts since building my sister's computer in late 2006, though I have been trying to catch up. So I'll just jump into what I need and if you have any suggestions, please let me know!
I plan to use the computer for heavy gaming (Age of Conan, Crysis, Oblivion modding) and movies, but also fairly heavy 3D graphics (3DS Max, Photoshop, Painter) as well as coding and scientific modeling software (earth physics models, fairly high resource requirement). I don't plan on overclocking.
Case: I want something big enough for a huge power supply, 2 graphics cards, 2 hard drives, quad core and inexpensive-to-replace fans ( < ~20 / fan ). It can be a bit noisy because I tend to have music on anyway. Color doesn't matter since I may paint it anyway if I have time (painting it green perhaps! :D ) I was thinking this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16811103011 ? I don't know if it will all fit, though it should, right?
CPU & motherboard: I'm thinking quad core here. Something that will last me a good 3-4 years, barring failure.
Video card: dx10 capable, SLI... are physics cards worth it?
Hard drives: 1 fast access drive, 1 long term storage drive... this seemed to work well for me before.
RAM: 4 gb with the option to expand over time
Sound card & speakers: Need good ones for regular movies & music.
Other: I'd like some kind of LED output of internal temp, whether it's on the motherboard or on the case... doesn't matter. I think that's nifty. ;)
My current monitor is a 21" dell widescreen, it's great so I'll be ok with it. I can buy the OS (Windows Vista 64 bit) from school, and I have the keyboard and mouse. I'll need a dvd player/burner... blu-ray isn't out for PCs, is it?
My limit is minimum $2000, maximum $2500. I would like to build it now, although if there is some amazingly awesome thing coming out soon, let me know and I might opt to wait...
Thank you for any suggestions! I've been researching some options but would love to hear some of your ideas as well. :)
The Q9xxx quad core procesors and nvidia 9000 series video cards are the next big things to come out within the next month or so.
If you want something now, the e8400's or q6600 is a good processor choice, and single/dual hd3870's or 8800gts(512mb), are good choices. I would personally go with the hd3870', since crossfire works on p35 & x38/x48 platforms.
Physics cards are pretty much useless now imho...
Lian-li & Antec(p180/182) are regarded as solid, no-bs case makers. Thermaltake, Gigabyte, & coolermaster are pretty decent too.
Speakers - usually recommended are the Klipsch Promedia 2.1's, Logitech z2300 (2.1), Logitech z5500(5.1), and if you can find them anymore, Swan M10's.
2x2gb of ddr2 800 or 1066 ram should be fine.. crucial, g.skill are my preferences..
You can have blu-ray & HD-dvd players for your pc, but of course, you'll need at least a 1980x1200 resolution(24" or higher) to utilize 1080p's potential, as well as the proper software.
If you need something right now, here's one setup to look at....
$130 - Gigabyte GA-P35-DS3L
$272 - Intel Q6600 G0 revision
$50 - ZEROtherm Nirvana NV120 CPU cooler (free shipping & $10 mail-in rebate)
$95 - G.Skill 4GB (2x2GB) DDR2 800 kit (free shipping)
$30 - Samsung SH-S203B SATA DVD burner (free shipping)
$120 - Seagate 7200.11 500GB SATA HDD (free shipping)
$320 - EVGA 512MB (G92) 8800GTS ($30 MIR)
$89 - Corsair VX550 550W PSU (free shipping & $15 MIR)
$1106 - Total (not including shipping, taxes, and/or rebates)
Cases are a matter of personal taste, but here are some other options:
Cooler Master Elite 330 RC-330-KKN1-GP ATX Case - $35
Cooler Master Centurion 534 ATX Case - $40
Cooler Master Centurion 532 ATX Case - $45
Cooler Master RC-690-KKN1-GP ATX Case - $65
Cooler Master Mystique RC-632S-KKN1-GP ATX Case - $65
Antec NSK4480 ATX Case With Antec Earthwatts 380W PSU - $70
Lian Li PC-7B Plus II Silver ATX Case - $90
Antec P180B ATX Case - $109
Antec Sonata III ATX Case with Antec Earthwatts 500W PSU - $110
Antec P180 ATX Case - $115
Antec P182 ATX Case - $124
Thermaltake Armor VA8000BWS Full Tower ATX Case - $135
Lian Li PC-A16A ATX Case - $150
Cooler Master Stacker RC-830-SSN2-GP Full Tower ATX Case - $150
Cooler Master Stacker RC-832-KKN1-GP Full Tower ATX Case - $150
Thermaltake Armor VA8003BWS Full Tower ATX Case - $151
If you need some case fans, pick up some Yate Loon 120mm fans. You can find them at various locations (e.g., SVC, Jab-Tech, or Xoxide) for around $4-$7 per fan.
The motherboard is based off the P35 chipset, which supports the 45nm Penryns (including the incoming Q9xxx processors). The Q6600 is a good processor, and overclocks well, if you decide later on that you want to prolong the life of this rig (or the processor itself).
Raptors would count as the "fast" drives, but they're no longer worth their price premiums. The newer drives out now (including the 7200.11 that I recommended) can compete with the Raptor in certain benchmarks. I chose the Seagate 7200.11 due to its performance and Seagate's five-year warranty.
Blu-Ray and HD-DVD drives are out, but they're expensive. I wouldn't recommend one at this time.
With the monitor you have, you don't really need a dual video card setup; the 8800GTS is more than enough. (For Crysis, though, you may want to also consider the HD3870x2 or a second-hand 8800GTX.) EVGA also has a 90-day step up program that allows you to trade in your current card for a new one (while paying the difference). That, plus its lifetime warranty, makes it a good choice.
Speakers are very subjective (I'm not going to recommend a set, lest I offend some audiophile somewhere...). But onboard sound is good enough nowadays for music and videos. Try it first, and if you don't like it, then get a sound card. (If you really need a speaker recommendation, JamesL gave you a few "good" ones.)
You need a 64-bit OS to properly utilize all 4GB of RAM. Vista Home Premium is also better supported drivers-wise than Windows XP Pro x64. Since you are getting new hardware, you won't have many drivers-related problems that people have complained about since Vista's inception.
The power supply is good enough. If you decide upon another one, the key thing to look at is the amount of power that the PSU generates through the 12V rail.
PSU suggestions:
http://forums.extremeoverclocking.com/showpost.php?p=1590883&postcount=193
http://www.jonnyguru.com/forums/showthread.php?t=1460
http://www.jonnyguru.com/forums/showthread.php?t=103
PSU FAQ: http://www.jonnyguru.net/forums/showthread.php?t=1036
Tiraids has a good setup for you to consider. With what you plan to use the computer for, definitely consider a Quad over a Dual Core. If you're looking to OC, then the Q6600 G0 is your best choice (and will likley remain so even after the Yorkfields are out, due to its higher multiplier.) If you know you're not going to OC, or don't particularly care about a high OC, you can wait until the end of March and get a Q9450. Note that the Q9450 will be about $100 more expensive than the Q6600 when it launches.
The only thing I'll add is my standard spiel on SLI. You should only consider SLI if a) you're gaming at a resolution of at least 1920x1200 and b) you can afford to get two cards now. With the power of current cards, an SLI setup will be a complete waste of power and money for lower resolutions. The second card will sit idle twiddling its thumbs, and you won't see an y significant performance benefit. SLI is an upgrade path is never worth it either, as by the time you're ready to plop down money for that second card, a newer card will likely be out that outperforms two of your older cards in SLI. Considering that you can sell the original card when upgrading, and that nVidia rarely reduces retail prices on older cards when new stuff comes out, simply upgrading to the newer card will also prove to be the more economical option.
Good stuff, but I think I'd opt for 8 GB of DDR2 800 RAM and the QX9650 processor given your budget and that you don't intend to OC. Should you decide you do want to OC, the QX9650 can do so without any effort.
Also, with 8 GB of RAM, you might want to look at setting up a RAM drive with half of that memory. You'll be amazed what that will do for applications such as Photoshop.
That's an unnecessary waste of money. Unless the OP was heavily into using VMs, he wouldn't see much benefit into utilizing 8GB of memory. The RAM-Drive is an expensive toy that is designed for DDR memory, is incapable of using 2GB memory sticks, and only utilizes the SATA/150 bus.
Also, the Q6600 could provide just as good of an overclock as the Extreme Edition QX9650 yet costs only a fraction of that amount. But the OP isn't overclocking at this moment, and the majority of the programs he intend to use are multi-threaded for multiple core processors.
Agreed. Unless you're utilizing multiple VMs, 8 gigs of RAM is a waste. Dido on the Extreme chip... It's an extreme waste of money, unless (and this only applies to the QX9650) you are a die-hard OCer who must have a 4ghz+ Yorkfield OC. Since the OP is not OCing, there is absolutely no reason for him to get the Extreme chip.
Dido on the Extreme chip... It's an extreme waste of money, unless (and this only applies to the QX9650) you are a die-hard OCer who must have a 4ghz+ Yorkfield OC and already own a VapoChill LightSpeed or similar..
Fixed.
I guess they aren't that bad. I just see Antec and PSU and panic.
LOL! Your famous Antec hatred:)
I panic when I see Apevia and PSU together. If a site recommends an Apevia PSU, then its off my list of review sites to go to.
You mean the ones that melt and catch on fire at 50% load? But Danny, they're such pretty /colors/.....
here I come :D, the dude said $2000+
this is a plan but u'll have to wait for about 30-50 days for all the parts to be available
Intel Core 2 Quad Q9450 (45nm) let say $350
ASUS Rampage Formula lets say $320
G.SKILL 4GB(2 x 2GB) DDR2 1000 Dual Channel Kit $114
Nvidia 9800GX2 lets say $450
Thermalright Ultra-120 eXtreme CPU Cooler around $60
burner, HDD, PSU (like tiraides said) 30+120+89= $239
lets see..... $1533 :eek: I thought I can hit $2000
ABS Tagan BZ Series BZ700 $179
+ some Western Digital Raptor
+ replace the monitor
+ go water cooling
thats the maximum I can give you (I can’t recommend QX CPU’s and DDR3 and SLI boards :D)
its looking more and more like the first rev 9 series will just be reshashed G92s. I cant wrap my head around Nvidia being that lazy, I mean they have to be working on something, but all the leaked pictures say otherwise. Everyone keeps talking about a D9E aka G100 aka 9800GTX, but no pics or specs yet! :mad:
As such, get an 8800GTS 512mb, great great value. Just to clairfy to the OP, the 8800GTS 512mb is based on the G92, making it superior to the 8800GTS 640mb which is built on the G80, misleading as it may be.
Normally I would suggest the E8400, as its a simply fantastic value and an amazing overclocker. However, as you're not overclocking, and are looking for quad core (which is a good idea if you're upgrade cycle for CPUs is upward of 2 years), then get a Q6600, or wait. The Quad Core 45nms are almost here. I cant remember anything specific but I believe intel plans to have some midrange 45nm quad core CPUs out by the end of Q1 08, I'd look into it though.
Now as for motherboards... your f00ked. Theres no hardware incompatibility, just some squabbling NV and Intel execs, but it achieves the same ends: no 45nm quad core on 780i, or at least as far as the rumors go. 780i will support wolfdale, the dual core 45nm chips from intel, but not yorkfield, the quad core 45nm chips from intel --or so I heard.
edit: sorry this computers freshly formatted, adobe sites down and the spec manual for 780 from evga is in PDF format. So I cant tell you exactly whats compatible since I cant get acrobat reader installed... if only i could remember that tiny little pdf reader ap...
you could go with a nice P35 based motherboard, but then SLIs out. You could go with a Crossfire P35 (which is still the ugly 16X by 4X) or X38 boards for a couple of HD3870X2s, but the HD3870X2s performance is only minimally better then the 8800GTS 512mb and costs significantly more.
In terms of ram, stick with a pair of 2 gig sticks of DDR2, or four 2 gig sticks for 8 gigs if you feel really nuts. 8 gigs of memory is pretty well hard coded into my old brain as being server territory, but, with ram prices so low and Vistas indexing so aggresive, maybe 8gb is primed to enter the PC realm? DDR2 certainly means that any future upgrades will be more difficult but DDR3 prices are totally unreasonable and they arn't exactly rock solid.
If I were you, (and someone was standing beside me with a knife threatening to chop my arm off it i hit F10 on post [read: overclock]) I'd first consider an E8400 with 780i and couple of 8800GTS 512mb, but would put some serious consideration into the P35 motherboards. remember if you don't plan on going SLI right off the bat, there will be a cheaper better single card solution from NV by the time the next gen comes into full swing.
If you do end up choosing to go with an ATI graphics chipset, buy from Visiontek, they're the only company with any reputation in the business. Power color is ok too but they arn't aggressive in their pricing (over here at least), so theres really no point in considering them. HIS and Sapphire both have infamously bad customer service. On the NV side (and this is rather sad), virtually every board partner is reputable. XFX, BFG, and, of course, EVGA, all have superb support services, and the 2nd tier partners, such as Gigabyte, Asus, Galaxy, MSI, PNY, Leadtek (aka Wintek aka Foxconn) all have traditional 4-6 turnaround respond-the-next-day customer support.
edit: oh and last I checked, Vista and SLI still wasn't a pretty picture. There was a pretty livly thread created over a guy at Xtreme systems who created a chart of Crossfire and SLI, comparing two 8800s to two HD3870s a couple months ago. The two 8800s persistently outperformed, but crossfire persistently scaled better. The only answer I can think of having seen first hand that on XP pro this is not the case is that vista SLI drivers sucked.
And uhh... well, I spose if your totally uninterested in overclocking (but comon man this is the hardware overclockers comparison page!), the Spider platform might be worth a glance... you can get some mighty cheap quad cores which do perform better then the AX2s clock for clock (by 10-15%, still under the core 2 by say 10-20%, clock for clock), and they are cheap, and 790FX is a superb platform, and a couple (or even four) RV670s isn't such a bad idea...
as for hard drives, I think a Raid-0 array of 7200.11s, or two 7200.11s put in seperation cleverly will offer sustained read speeds greater then that of a single raptor. There really hasn't been much in the way of new 10k rpm hard drives. After the raptor, that was it. I believe it pulls down somewhere on the order of a sustained 72MB/s, where a raid-0 array of 7200.10s leaps around from 50-80MB/s (depending on file size). The 7200.11 couldn't do any worse.
anddddd I think that about does it... I'll update a little later with more specific items, after I've done a little homework on the current state of hard drives and Wolfdale/Yorkfield compatibility.
680i will not support 45nm Quads. Unless something major has changed, 780i will.
SLI support is getting better under Vista with each new driver release. It's pretty solid now.
Talking about the price. The LEDs are a personal preference thing... I think it looks a little too riced out, but I'm big in to the "everything must be featureless flat black, sometimes blue accent LEDs" thing. ;)
And I'm big on the "not having to spend too much money when you don't have to" thing.
firas: One thing that you missed with your $2000+ rig is that the OP also wanted to purchase speakers, multiple hard drives, a fan/temperature monitor, and a case large enough to hold everything in. (Oh, and his budget maxes out at $2500.) I didn't include those things in my setup, so I left plenty of money remaining so that the OP could choose/get what he wants without worrying about bursting the budget.
And if the OP doesn't like my setup, well, he has yours to consider as well.... ;)
your setup is smarter/wiser than mine, I admit that P35 board still the wisest choice until now specially that all these fancy X38/X48 boards will become old fashion when the new socket arrives
but he set a big budget that can handle X48 boards, and it&#8217;s not a bad idea to get these boards specially that a board like the Rampage Formula will surely offer him a great OC capabilities and will offer the PCI-e 2.0 port that will match his graphic card (8800GTS512 or 9800GX2), and will give him 2X x16 slots (2 ATI cards)
Q6600 (G0) is&#8230;.well&#8230;.. it&#8217;s the Q6600, the name speaks for itself
but Q9300 is about the same price and has done some great benches here and outmatched the Q6600 in most benches and reached 3.75Ghz with OC
so it could be the smartest choice if he can wait (talking about quads only)
but the Q9450 is &#8230;.well&#8230;..I&#8217;m sure the name will speak for itself very soon and though the price difference between it and the Q9300 is not small, I guess that difference doesn&#8217;t worth sacrificing the Q9450 :rolleyes: People paid around $800 for the Q6600 B3 when it first arrived and Q9450@about $350 is a really good price
btw, the setup I mentioned will probably be my future rig :D (with the Silverstone TJ07)
You've neglected to mention a vital part about those OC benchmarks -- they were obtained through water cooling. Correct me if I'm wrong, but most people are having problems getting past 400MHz stable (FSB speed) through air cooling (which is important, as a lot of people still use air cooling when overclocking).
For now, the Q6600 remains the best choice for a quad-core due to its high clock multiplier and its price (I've seen the Q9300 fluctuate in price between $280 and $350, while the Q6600 varies between $240 and $300). I don't know when the Q9xxx CPUs will drop in price; if you recall, it took a while for the Q6600 to drop down to its current "sweet spot."
And regarding X38/X48, if you don't need the native CrossFire support (and you can't use NVIDIA cards with CrossFire), then there's really no justifiable reason to go for a board right now. The P35 could overclock just as well while being comparatively more stable... not to mention relatively cheaper. DDR3 is ridiculously expensive compared to DDR2 (especially now, when you could buy a 4GB DDR2 kit for under $100), and PCI Express 2.0 cards are backwards compatible with PCI Express 1.0 (aka PCIe x16) slots. I doubt that much would change between now and Nehalem's arrival (which would supposedly make all LGA775 boards "obsolete") that would make X38/X48 the board of choice, even with the arrival the Penryn-based processors.
I still feel that it doesn't make sense for the OP to go the route that you're suggesting, but to each his own.
I love that the new architecture is codenamed Nehalem. It sounds like some kind of crazy outlandish god.
oshi! Nehalem is coming! :D
The name does sounds very biblical, perhaps even Kabbalist Jewish, and since Merom and Yonah were developed in Israel and had Hebrew names, I just assumed Nehelem did as well.
