$2000 for pre-built CAD-like workstation
paperwastage
This is for a workstation in a computer lab. Mostly web browsing, general multitasking stuff, maybe some CAD-work(hence a decent GPU). Not sure if all programs have 64bit compatible, so aiming for a 32bit OS(4GB RAM).
IT HAS TO BE prebuilt (aka Dell, HP, no macs unfortunately)
$2000 excluding tax or shipping
3) Where do you live?
Baltimore MD
Planning to buy from Dell. Looking at what is good for the budget. 2 Options after this intro stuff
None
6) Will you be overclocking?
None
19-24". Not sure if I should skimp on some money to spend on dual screens
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Esata
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
32bit Windows 7 and XP
System 1
Dell Precision T7500 Workstation
W7 Pro w/ XP Mode
Quad Core Xeon E5606 2.13ghz, 8MB L3
1GB ATI FirePro V4800
3 yr basic limited warranty, NBD on-site service
3GB DDR3 RDIMM 1333 ECC
250GB SATA, 8MB cache
320GB SATA, 16MB cache
16x DVD+/- RW
Dell P2210 22" Monitor (vga, dvi, dp)
System 2
Dell Optiplex 990 Minitower, 90% efficient PSU
W7 Pro w/ X PMode
Core i7 2600 (3.4ghz, 8MB L3)
3 yr basic limited , NBD on-site service
4GB DDR3 1333 Non-ECC
500GB SATA, 16MB
1TB SATA, 16MB
6X BluRay Writer
1GB AMD 6450
Dell E2211H
Dell P2211H
vPro Technology
USB 3.0
System 3
Dell Precision Workstation T1600
Quad Core Xeon E3-1225 3.1GHz, 6MB L3
FreeDOS
265W 65% Efficient PSU
4GB DDR3 Non-ECC 1333
1.0GB nvidia Quadro 2000
2x250GB 7200rpm 8MB cache
16x DVD+/-RW
Dell P2210 22"
USB 3.0
4yr basic hardware service + nbd limited onsite
First one's processor isn't that fast
Second one only has a 6450 ATI, cant get any higher (etc 6670)
Third one's processor Xeon E3-1225 is based on SandyBridge, but cant find any good reviews for it. Powerful GPU
Processor wise, both the 2600 and E5606 came out this year, but the 2600 looks way more powerful. The target for this computer isn't for continuous lab/number crunching that requires ECC mem, but the 2600 comes with a way inferior GPU
I would say CPU...
anyone know the difference b/w Xeon E2-1225 and i7 2600? They are both Sandy Bridge arch, i7 has 2MB more L3 cache plus a little more ghz and turbo, but other than that, they're just binned as Workstation vs Consumer parts right?
From what I can find out the E3-1225, the difference between that and the i7 2600 is the E3-1225 doesn't have hyperthreading.
well, i'm not even sure if that's right
wikipedia and some sources say 4C/4T
some sellers say its 4C/8T
and it looks like E3-1225 doesn't have turbo?
guess I have to wait until Intel officially releases it
