$200 range GPU
m_cochran
What is the best graphics card right now in the $200 range? I am looking at either a 7870 or a GTX 660.
Right now I have a 6850 1 GB, and am looking to upgrade.
I'd get a R9-270 for $180ish and overclock it.
It's basically a 7870 that's been buffed up a little here and there and performs pretty darn well for the money.
There is always the R9-270X for $200ish which is the same thing already overclocked for you but me, I'd save the money and overclock a 270.
I just replaced my GTS 250 with a EVGA 660 FTW 2GB /w ACX cooling and I love it! I can play Skyrim on max settings and BF4 medium settings. Huge upgrade.
Which resolution? What are the average frame rates?
Re-quoting for emphasis:
Well first and foremost, what PSU do you have?
a 670 would be around $225 and is a bit better than a 660, though a 660ti for $175 or less would be a good deal IMO.
I don't think a 7870/270/270x would get you where you feel your money was worth it, at best they seem like a slight upgrade, or a sidestep. If you are looking to stay AMD I'd save up and pay no more than $310 for a 280x, though most are backlogged so you'd probably have to wait a few weeks before actually getting the 280x.
You can pick up a used GTX 680 for $250 or less now.
