nxcess
- Dec 22, 2004
Yeah I know. It's BestBuy but you can't beat 20% BCB. Search bing for ipod. I just got 140 off a 699 laptop.
Tax.....
Tried all the search terms but couldn't find it. Also tried browsing stores and it's not there either. Is it dead or am I using the wrong search terms? If anyone could help I'd really appreciate it since I'm looking to buy a PS3 and may end up just going to B&M BB if this doesn't work out.
Or go to the Bing Cashback site, look under stores and go straight to Best Buy.
Make sure you're checking the sponsored links.Does it have to be only PS3?
What if I want to buy a DSi ?
When I typed PS3 in the Bing search, I get the 20% off.
When I typed the DSi in the Bing search, I did not get anything.
Also, it doesn't matter what you search for to get Best Buy to show up - you can search for a PS3 and buy a 360 once you get to best buy.com.
Bleh... 20% on ipad would have been niice
As I said, I ended up just using the "PS3" search and it brought it up. With tax and shipping its cheaper for my to buy the 3D Vision kit through Tiger Direct and the 12% off and google checkout (another $5 off). Anyone find any better deals?
Its not showing up for me either.
Never mind. Took about 2 dozen refreshes.
You can't use google checkout with bing cashback.
Nic find...I clicked through but don't see anything on BB's website.
in any case, if you search for SKU 9740848 it's a $217.99 notebook. With 20% BCB that would be $174.40
For the n00bs each search term needs to be something BB would sell try thinking a bit instead of crying the "it doesn't work!!!!! ZOMG!!".
I just tried the following with successful results:
XBOX 360
nintendo ds
canon camera
sony camcorder
Garmin
webcam
took me all of about 5 minutes and a little bit of brain power...
and yes it does work I just saved $194.00 on my purchase.
http://i23.photobucket.com/albums/b378/nocontrol5150/Untitled.jpg
TiVO Premier? Worth while price-wise with the BCB?
