So, hoping to get some thoughts from others that may be running on a 20-30-20 setup. I have run dual monitors for the last 6 or 7 years and had gotten very used to being able to have a full screen app on one screen and secondary docs or web browsers open on the other screen.
Recently I picked up 3 U2412's to run in portrait eyefinity. For certain things (especially document work) its wonderful. The total resolution and screen size is amazing while keeping a relatively normal aspect ratio, and using a single 24" for multimedia/gaming now appears drastically small. Additionally, I'm not really a huge fan of the ridiculous aspect ratio in widescreen eyefinity. And it is true that for many things the bezels do just fade away when you're in the middle of something, while they are harder to ignore in portrait than widescreen.
However, certain things don't lend themselves to portrait setup - widescreen apps such as photoshop are just frustrating on p-p-p with the bezels, no matter how used to them I get. And you definitely can't run it on a single portrait panel. And I don't have a desire to move my monitors physically back and forth depending on what type of application I currently am in.
So the idea of 20-30-20 seems appealing from the prospect that any widescreen apps can easily fill a large 30 with a pretty solid resolution (granted, its no 3600x1920, but there's no bezels to contend with ever). And I'd still have portrait screens for single secondary doc/web work. But it obviously means I wouldn't be able to run eyefinity anymore - but I'm not sure if that'd necessarily be a horrible thing if the apps were running at 2560x1600.
In any case, I have a short window that Dell will still switch these setups out, so I'm hoping to find some ideas to guide me either to appreciate the eyefinity resolution i currently have or to swap to a U3011 with 2007's.
Thanks guys.
Thanks guys.
