Culprit #1
AMD Athlon 1 Ghz
256 Mb Generic RAM
IWill mobo (working on finding model #)
Ati Rage IIC AGP
40 GB WD
Netgear NIC
Generic CD-ROM
Windows XP SP1
Symptoms
From day 1 it was flaky randomly hanging and just kept progressing to the point that it randomly locks doing anything/nothing
Underclocking to 800 Mhz allows me to start doing some archiving of data before it hangs after a while
Passes memtest/scandisk/WD diag w/o errors
Culprit #2
PII 350 Mhz
32 Mb PC100 Generic RAM
Asus P2B mobo
Cirrus Logic 5465 AGP
Intel Pro NIC
Generic CD-ROM
Windows98 SE
Symptoms
Seemed stable ran stress tests and shes passes them all
Randomly boots from CD though.....half of the time shes good...other half not so good
1/10 POSTs list undefined hardware error, quick tap of F1 and we're up and flying
Windows98 no longer recognizes CD-ROM (BIOS does though) I know theres a fix but MS Knowledge Base isnt behaving right now
Suggestions would be appreciated
Working on BIOS flashes for both boxes as I type
AMD Athlon 1 Ghz
256 Mb Generic RAM
Ati Rage IIC AGP
40 GB WD
Netgear NIC
Generic CD-ROM
Windows XP SP1
Symptoms
Culprit #2
PII 350 Mhz
Asus P2B mobo
Intel Pro NIC
Generic CD-ROM
Windows98 SE
Symptoms
