1TB preloaded ACER drive won't fully format
Binar
I bought an ACER system, and I swapped the HDD right off the bat with a SSD. I tried to format the HDD (1 TB WD Blue) either quick or slow format but it looks like the HDD still has some files left. Properties reads used space 118 MB and Free space 913 GB. I'm sure these might be some ACER preloaded crap but I have no idea how to delete/format or even see what the files are
1TB should be around 931.323 GiB. Windows shows GiB but calls it GB. Have you enabled the hidden and system files?
There's probably a hidden "recovery" partition. Enter the partitioning software of your OS and see if you can find it.
Ya I belive it has a recovery partition set up by Acer
I'll take a look in 30 min
The ~120MB is most likely being used up by the System Volume Information folder, $MFT, etc.
Disk management shows:
600MB Healthy (recovery partition)
300MB (EFI system partition)
913.9 GB NTFS Healthy ( Primary partition)
16.61 GB Healthy (Recovery Partition)
no..i just don't know how to delete the recovery partitions and have 1 big volume
Open command prompt with admin privileges and type:
Code:
diskpart
list disk
select disk 0 (or whatever your HDD is)
clean
exit
exit
Then format the drive again and it shouldn't have the recovery partition anymore.
Code:
diskpart
list disk
clean
exit
exit
I figured the solution myself and was ready to post it here. I did exactly what you suggest with the only exception when you go to run and type CMD make sure you push ctrl+shift+ enter to get admin privileges
also after you exit cmd go back to disk management under windows to format the partition
I typed the extra steps in case other users need help like I did
TY guys
