1TB drive
Discussion in 'SSDs & Data Storage' started by counihan3, Mar 20, 2012.
  1. counihan3
    counihan3 [H]Lite
    75
    May 22, 2008
    I don't think that I want to use my old hd in my new system so I am looking at getting at new 1tb drive. Should I go with the WD Black or the Seagate Barracuda?
  2. Dangman
    Dangman Ninja Editor SuperMod
    46,670
    Dec 15, 2005
    Seagate if you're really cheap. Otherwise, I'd go for this Hitachi:
    $137 - Hitachi Desktar 7K1000.D HDS721010DLE630 1TB SATA 6.0Gb/s Hard Drive
    The WD isn't worth considering since it's significantly slower than the Seagate and Hitachi drives.
  3. counihan3
    counihan3 [H]Lite
    75
    May 22, 2008
    Doesn't Hitachi have a high failure rate? I still remember the deathstar drives.
  4. Jonowxeno
    Jonowxeno Limp Gawd
    342
    Mar 10, 2011
  5. Dangman
    46,670
    Dec 15, 2005
    As Jonowxeno said, not that bad. The Samsung drive that Jonowxeno posted is a little slower than the Hitachi but is faster than the Seagate and Western Digital. The take-away is this: Do not get the WD1001FALS as it's a very slow 1TB drive compared to other 1TB drives on the market.
  6. counihan3
    counihan3 [H]Lite
    75
    May 22, 2008
    Thanks for the help, I am just looking for a drive to go with my ssd.
  7. ckryan
    ckryan SSD Abuser
    619
    Nov 6, 2010
    If you're looking at pairing a SSD with a HDD, I'd personally get the quietest drive I could find. I don't really need much storage, so I got a USB3 external unit from Seagate with a 2TB 5900RPM drive. It's fairly quiet.
  8. counihan3
    counihan3 [H]Lite
    75
    May 22, 2008
    I ended up getting the seagate because it was cheap, after buying all of the other components I need to save some money somewhere.
