After looking at entry level 1TB drives, I found this: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152102 Now I know Newegg reviewers aren't exactly known for their credibility, but I just can't shake the feelin that this guy might know what he is doing.
"Cons: I had hard time install this drive. In the BIOS and windows, it only shows 32MB as a capacity. I searched the web and found out you need to run HDD Capacity Restore Tool to make it 1TB. SInce I'm running vista x64, I had to use other machine to run that tool (that tool doesn't support x64 OS). I ran it couple of times, but it only restored to 32GB... I almost gave up, but suddenly it shows 1000GB after running this tool over and over."
Is it possible this really happened, and is it something common with these drives?
