I've wanted to go WC for quite some time now, and I feel like I'm finally ready to make the jump. After studying threads like crazy I think I'm at a point close to ordering.
Basics about my system, and the goals:
These are the parts I currently have in mind. I'd like to get approval from a few members to make sure I haven't chosen anything completely off-the-wall or incorrect. I'm also hoping to get help with anything blatantly obvious I may have missed. I have no other WC parts or accessories other than what I'm listing, so if I'm missing something feel free to chime in! Alternate suggestions are certainly welcomed.
Thanks in advance!
- i7 930, Antec P182 case (case not entirely optimal, I know)
- Looking to build a CPU-only loop
- Looking for good performance-to-dollar ratio (bang for the buck)
- Looking to keep things simple, not interested in anything flashy
CPU Block: Swiftech Apogee XT
Pump: Swiftech MCP655
Radiator: Swiftech MCR320-QP-K
Reservoir: Swiftech MCRES-Micro Rev 2
Radbox: Swiftech MCB-120
Tubing: Masterkleer Tubing 7/16" ID 5/8" OD
Fittings: (4x) Bitspower True Silver G1/4 High Flow 1/2" Barb
Liquid: Distilled water (Wal-Mart, supermarket, etc.)
Additive: Silver KillCoil
Fans: Scythe S-FLEX SFF21E 120mm
- Not looking for anything expensive here since it's my 1st time.
- I have no idea on the number of feet I should buy in order to have enough for a learning curve. 10ft? 15ft?
- Will I need any kind of special scissors / cutting equipment?
- 2 barbs are already included with my block, so I'm good there?
- 2 on the pump are fixed, so nothing needed there?
- I absolutely need 2 for the radiator, correct?
- The additional 2 I planned on using in place of the reservoir's supplied plastic barbs. Good call or unnecessary?
- I'm also debating compression fittings rather than the barbs. If I go one way, I'd like to go all the same - so that would mean purchasing 6 compression fittings rather than my planned 4 standard barbs. The cost on that one certainly adds up quick - would it be worth it for a first-timer in terms of ease & security? Any other opinions?
- Already have these
