- May 24, 2006
SO I have had this system for a while, but only now am I pushing it a bit on the OC front:
mobo: P5B Deluxe wifi/AP.
CPU: Q6700 under a scythe Ninja all-copper edition, stock voltage (reported as 1.352v in CPUz under load)
ram: Crucial Ballistix DDR2800
Video: 2xATi 4850
I got it up to 3.3ghz (10*330) just by raising the fsb. Totally stable for 30min under OCCT. However, when I bump it up to 3.4 (10*340), I get a full system reboot in OCCT after like 30 seconds, and in GRID after about a minute or two of racing.
I assume that this is a symptom of an unstable OC, but not sure where to go from there... Is this a ram issue, or maybe the CPU needs more voltage? I know cpu heat is not an issue, as under load at 330mhz, I only hit the high 40's.
Video: 2xATi 4850
