Anyone know about the E4400 (2GHZ, 2MB cache, 800MHZ fsb, 10x mult I think)? I'm thinking of building an HTPC with P5K-VM + E4400 + Crucial Ballistix PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-12.
Any thoughts on if I should be able to overclock to around 2.5GHZ OK, and with stock cooling?
Kent,
Maybe its something in how you did the BIOS update? Corruption possibly? Did you try to revert back to the old BIOS to see if that cleared anything up? Might be worth a try before RMAing it.
Well I'm getting 2.5GHz with the same componenents on a far less overclockable ASRock 945P motherboard. You should have no problems achieving 3GHz with the stock cooler.
With the E4400 only having an 800mt FSB would I be better off with 667mhz memory? I'm considering: Corsair XMS2 TWIN2X2048-5400C4 2GB 2X1GB PC2-5400 DDR2-667 CL 4-4-4-12
Will the fanless Gigabyte 8500GT fit in this motherboard OK? Planning on putting it in the NSK2400 case.
the nsk2400 (I have one) doesn't have much clearance above the slots; 1cm roughly.
The card is normal height; it's just thicker than normal due to the enormous heatsink (and a tiny bit longer than normal since the heatsink runs off the end of the card).
Thanks guys. Anyone know about that Corsair XMS2 memory? That's the last thing I'm waiting on before I buy the system. If I should be able to hit at least 2.4 GHZ with the E4400 and that memory then I'll be happy and good to go.
Did you guys find it necessary to update your BIOS In order to get a better overclock? I can't seem to get higher then 3.1GHz on a Pentium D 820 (ES). My RAM is rated DDR2-1100, I don't see whats wrong outside of an old BIOS.
Hey guys I'm really interested in purchasing this board to go along with this setup:
Q6600 G0
2GB Crucial Ballistix DDR 800 or 4GB Crucial Ballistix DDR 800 in the future
Right now i already have the CPU and the 2GB of ram. I just wanted to know if i would have problems running with either setup on this board. Also with the parts that i just listed, should i be looking at running this on the GA-G33M-DS2R or would i be fine with the P5K-VM?
At the end of the day all i want is some light overclocking. The most i want my quad running at would be 3ghz and also be able to run possibly with 4GB of ram. Cooling right now isn't an issue because this setup might be going in one of my old Full ATX cases. Thanks for your help guys.
Q6600 G0
Hmm.. I wonder if that value increases if you aren't using on board video? And does anyone have info on PCI lock for this motherboard????????
I'd like to know how the mini ninja fits on this boardand I'll be getting a Scythe Ninja Mini soon so cooling will be even less of an issue
The Mini Nin should fit. It'll be a case issue if anything I'm thinking.
