DaConfusion
- Dec 14, 2005
No gaming.
PC shall be used for Pro/E, Solidworks, 3D scanning, FEA, CFD, mathlab, mathcad for automotive engineering.
Expect attempts to load entire vehicle assemblies (rarely), primary use will be bracket/part design, vehicle packaging, and interface with 3D scanner.
With tax and shipping, absolute max is 1500, would be nice to get the final price to 1000.
3) Where do you live?
Houston, TX - New boss build!
CPU, memory, motherboard, video card, RAID 0 hard-drive setup, dvd burner, case, power supply, CPU fan
No parts will be re-used.
6) Will you be overclocking?
Maybe... I would like to set the PC to have software OC per Sandy Bridge during high / peak loads if possible.
If cost is too high, OC is not important.
A new monitor shall be purchased, ~200$ allocated for monitor (separate from 1-1.5k PC budget).
Order this week, willing to wait if better deals expected soon.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Support for newer technologies, such as USB 3, SATA 6GBs. I am going to update this post with any interface requirements of the 3D scanner. I doubt it needs anything old such as serial or parallel port...
NO. I will need to purchase OEM windows7. I think Windows 7 Pro is sufficient
Here is a preliminary list I have put together, I am hoping you guys can revise this with cheaper or better options:
CPU
Core i7 2600K LGA 1155 Boxed Processor Intel
$279.99 $0.00 $0.00
http://www.microcenter.com/single_product_results.phtml?product_id=0354587
Memory - I would like to revise this to ECC memory since this build is a pure workstation for long term use
Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3
$81.98 $0.00 -$0.00 (combo deal with mobo)
http://www.newegg.com/Product/Produ..._-na-_-na&AID=10521304&PID=3891137&SID=194r0
Motherboard
P67A-GD65 (B3) LGA 1155 MSI
$179.99 $0.00 -$20.00 (combo deal with mobo)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130574&cm_re=msi_p67-_-13-130-574-_-Product
Video Card/GPU - I have seen the perks of soft-modding for CAD performance increase, I need a card that can be soft-modded. Not interested in used video cards.
Radeon HD 6950 2GB
XFX - ATI $274.99 -$30.00 $0.00
Primary HDD
Samsung 1TB F3 HD103SJ 1TB
$64.99 -$0.00 $0.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Raid 0 HDD
1TB F3 HD103SJ 1TB
$64.99 -$0.00 $0.00
DVD Burner
24X Burner - ASUS
$20.99 $0.00 $0.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Case ATX
Mid-Tower HAF 912 Cooler Master
$59.99 $0.00 $0.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
Power Supply
750W EarthWatts Antec
$89.99 -$0.00 $0.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026
CPU Fan
Hyper 212 i7 Sandy Bridge
$29.51
http://www.amazon.com/gp/product/accessories/B002G1YPH0
Operating System
Windows7 x64 Professional OEM?
139$ via newEgg
Total $1,309.51
MIR -$50.00
Instant -$0.00
Shipping +$22.41
Final Total $1,281.92
Final total if NewEgg agrees not to charge shipping: $1259.51
Thank you for the help as always!
No gaming.
CPU
$279.99 $0.00 $0.00
Motherboard
Radeon HD 6950 2GB
Primary HDD
$64.99 -$0.00 $0.00
Raid 0 HDD
1TB F3 HD103SJ 1TB
$64.99 -$0.00 $0.00
DVD Burner
24X Burner - ASUS
$20.99 $0.00 $0.00
Case ATX
$59.99 $0.00 $0.00
Power Supply
$89.99 -$0.00 $0.00
CPU Fan
$29.51
Operating System
139$ via newEgg
Total $1,309.51
MIR -$50.00
Instant -$0.00
Shipping +$22.41
