OK, so I can get my 3850 to use my DVI=>HDMI converter to go full 1080p on my Sharp Aquos 46", however doing the same thing with my other PC with 1950Pro (same drivers and Catalyst setup) won't work. The display says incompatible video signal received. I however CAN output to the display from the 1950Pro with a DVI=>VGA and then run that to the VGA on the display and do full 1080p, but it doesn't scale quite right...
The 1950Pro Catalyst detects the Sharp HDMI, the 1080p and 60hz setting is the same at the setting on the 3850, all settings I can find are exactly the same. I even tried a different HDMI port just in case with no luck...
Anyone have any idea how to get this to work?
Thanks much
Thanks much
