littleworm
- Sep 30, 2011
So, I'm building myself and new gaming PC, and I have about 1700 dollars to do it with. Planning on building at the end of the year. As I haven't had a desktop in year I'll need all the parts including a monitor. Anyway thanks in advance for all the help.
Gaming and Web Browsing
1700 Dollars for parts, does not include shipping.
United States, High Point NC
Building this form the ground up, Case, CPU, Video Card, Ram, Heat Sink, PSU, Monitor, Motherboard.
No Parts
6) Will you be overclocking?
Yes
Buying a Monitor
End of the Year, most likely December
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Might add on in the future so Crossfire and SLI Support
No
No Parts
Yes
Buying a Monitor
No
