Mad_Vision
- Jan 16, 2008
I just got me the Elite 360. My 22" Widescreen max resolution is 1680 x 1050. The console does not have 1680x1050. What is the best option widescreen resolution for the 360? Thanks
The new update that will be out Nov 19th will have 16:10 support, including 1680x1050.
Till then just find the closest widescreen res.
Where the hell did you get novemeber 19th from?Last I checked it was just *late 2008* still >_<
When the New Xbox Experience is available on November 19th, a whole new way to experience games will be available.
Source
I suggest you run 1280x720 if possible to minimize the number of scaling processes the signal goes through.
I also strongly believe this upcoming "16:10 support" will be exactly the same as Microsoft's piss-poor "5:4 support", in that it will merely be a 16:9 signal stretched to 16:10. Because simply letterboxing a 16:9 signal would make too much sense.
They've already said it's the proper 1:1 type. Check the majornelson page (no idea where, it was a while ago).I also strongly believe this upcoming "16:10 support" will be exactly the same as Microsoft's piss-poor "5:4 support", in that it will merely be a 16:9 signal stretched to 16:10. Because simply letterboxing a 16:9 signal would make too much sense.
Letterboxing works and nothing gets stretched.
Well, I'll be damned. The inner cynic begs to say "I'll believe it when I see it, harumph!", but I do have my hopes up...They've already said it's the proper 1:1 type. Check the majornelson page (no idea where, it was a while ago).
Found it: http://search.everyzing.com/viewMed...x=17&col=en-all-public-ep&sort=rel&e=20458234
16:20 into that.
This is blessed news for me!
This is blessed news for me! I have a 24" LCD that doesn't support 1920x1080 & has a max res of 1920x1200. I hope that I can set any 16:10 res that my monitor can handle.
Nah, this is going to depend on how the monitor displays/scales non-native resolutions. 1280x768 actually stretches the image when displayed perfectly, as it is a 16:9.6 aspect ratio.When it comes to preserving aspect ratio, you should choose 1280x768, IIRC.
Don't get excited just yet. They haven't officially stated what resolutions will be supported. When they first announced the major update, they mentioned 1440*990 and 1680*1050, but not 1920*1200. As a result, I made sure to buy a monitor w/ 1:1 pixel mapping.
Could be worse, you could have the monitor support that the other console makers offer...If not, I'll make do with a lesser resolution.I wish MS would recognize (more) that not all gamers play on HDTVs, especially when many hardcore PC gamers own consoles as well.
Exactly. As a long-time PC gamer, I almost always prefer to play up close on a monitor.If not, I'll make do with a lesser resolution.I wish MS would recognize (more) that not all gamers play on HDTVs, especially when many hardcore PC gamers own consoles as well.
You and just about every other person who bought VGA cables.
November 19th just can't come soon enough.
17" CRT @ 1280x720 says: Fuck your update, I'm pretty on the inside!
I don't need no stinkin update. Mine scales already
Gotta find your small victories when you can, eh?
Before I got my 22" LCD I was gaming on a 19" Viewsonic flat screen CRT so I know how that rolls. Still I'd take my slightly stretched LCD image over CRT anytime for 360.![]()
Use 1366x768 and run a 1:1 ratio (possibly zoomed) if your monitor tries to stretch it.
