My setup..
Opteron 165 0551 UPMW
A8N-SLi Premium
OCZ Titanium 2-3-2-5 1GBx2 Kit
My OC Setup
1.41V
HT set to 3x
3-3-3-7 Memory Timings at 2.7V
HTT is sitting at 272
Memory Divider is 183 (Set with a64 tweaker)
2448Mhz is it's max stable... without upping my voltage to 1.45V (peaks at 278mhz). It'll run stable at this but the temp peaks out at 55C compared to 51C at 1.41 (which doesn't make it worth it to goto 278).
The system will hit 2.6Ghz stable for 6 hours for core 0 at 1.41V, it takes a significant increase in voltage to stablize the second core. Is there something I'm missing that I can tweak to help increase core 1's stability? I've tried underclocking the ram to 133, it doesn't seem to make a difference on the stability front.
I was really hoping to hit 2.6Ghz =/
Any suggestions would be appreciated.
A8N-SLi Premium
My OC Setup
1.41V
HT set to 3x
