1) What will you be doing with this PC?
Gaming and word processing
$1600-$2000 delivered
Brooklyn, NY
cpu, mb, ram, graphics card, heatsink, fans, case, ssd, hdd, psu, keyboard, mouse
Monitor (somewhat old, will replace later)
6) Will you be overclocking?
no
For now it's fairly old (no digital connections) but will be replacing with a current model a few months down the road (undecided on which)
soon
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
No specific requirements here, just the most bang for the buck
No, will likely go win7 (want to avoid win8) and prob pro since I want to RDP to the machine.
I've looked at cases a bit already, considering the Antec P280. I'm more used to Intel than AMD, though not opposed to either if it makes sense.
Brooklyn, NY
no
soon
