James Earl Ray
- Sep 7, 2004
Are you kidding? Nobody does the stupid CPU test. Looks at all the top projects. CPU testing takes too long and it doesn't matter.Luck.exe said:Not to kill your pride or anything, but do full testing, the normal test. Then post the score you get, just doing graphics is one thing, but that also doesn't mean much at all (neither does any benchmark for that matter though). Anyway good system though! I would like to see what you get with full testing though, just curious is all.
uwackme said:Noone does CPU tst cause its embarrassing to see the result of so much expense..vs... a much cheaper 2600+XP mobile in the same test.
But damn nice video OC....like to know what mod's you made to get to 600+/600+
uwackme said:HEHE... I'd esp like to know what CPU score you were able to get J.E.R.
Im only at 10.5x 240....I hit 898 cpu score....for $374 (2600+mobile, DFI Inf, 1G bh5)
Also, would luv to hear the mod's you made to the X800.... I will want to follow your advice on this. My 9800pro feels "dated"
My "dig" wasn't at YOU, just at AMD for doing such an unimpressive job on the A64's memory controller. Frankly, I'm underwhelmed. Horrible job building it into the CPU, its a control issue, not an engineering issue....and I dont want them controlling our options.
If you are going to do a memory controller, do a 256bit wide 4 channel, supporting 4 sticks of DDR (256,512,1G each). So 4x 512M BH5 running 250Mhz 11,2,2,2,cas2.0 in 4 channel goodness and we could get some serious bandwidth.
kcthebrewer said:<insert Jeopardy music here>
We are all waiting for the full run...
kcthebrewer said:Nice core clock, how are you cooling it?
