$1500 video/pix editor build
Nickbaldwin86
1) What will you be doing with this PC?
- Some gaming
- Mainly used for video and photo editing
- Web browsing and emails of course too
- Budget is around $1500 just for the desktop and looking to get a HP zr30w have another $xxxx set aside for that.
3) Where do you live?
- Washington
4) What exact parts do you need for that budget?
- Case
- MOBO
- CPU
- RAM @ least 6GB+
- PSU
- GPU
- H70
- SSD
- HDD
- DVD
- have nothing to reuse
6) Will you be overclocking?
- most likely not
- buying a HP zr30w
- basically will start once I put together a list
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
not a huge factor, I don't need crossfire or SLI
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Will be buying Windows 7 64bit home
I only want to buy from one store, newegg.com is normally the only place I look so.
Thanks
Nick
This should be good. I am assuming that the monitor is outside of this budget.
i7 930 CPU $289
ASUS Sabertooth X58
MB
$151
Corsair XMS3 3x2GB RAM $120
OCZ Vertex 2 120GB SSD $233
Corsair 650W PSU $89
HDs: 1 TB $70, AND 2 TB (slow for storage strictly) $110.
VGA: Wait for 6xxx series and perhaps even the coming GF110, or get a GTX 460 1GB. $250.
Xigmatek Heatsink and Cooler $45
CASE: Too personal, aesthetics involved as well. Approximately: $200
TOTAL COST: $1557
Upgrades I would make: More DDR3 and maybe a faster video card because of that crazy native res of your monitor.
I would strongly recommend that you prioritize graphics apps and current workflow data location for the second partition of your SSD (the first being for the OS). SSDs are absolutely essential for video editing if you are doing HD stuff.
That looks like a strong build and all I should need to build to get the job done and make the client happy.
Thanks nakedhand
Nick
A few problems with nakedhand's setup:
1) The motherboard is open box. Meaning that it may be missing items, that there may be previous undiagnosed damage made by the previous owner, and the possibility of a lack of actual warranty. Since this build is for a client, I wouldn't take the chance with an open box mobo for them.
2) The Core i7 950 is only $5 more and is well worth the extra $5 over the i7 930.
3) That Xigmatek HSF is a bit outperformed by this slightly cheaper HSF:
$30 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
I'd go with this setup instead:
$377 - Intel Core i7 870 CPU + Gigabyte GA-P55-USB3 Intel P55 ATX Motherboard Combo
$140 - 2 x G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
Total: $517 plus tax and shipping
About $40 to $80 cheaper than nakedhand's setup (using old and new mobo) but provides the same performance and an extra 2GB RAM. The only real tangible advantage a Core i7/X58 route is an extra two RAM slots. That's pretty much it.
You can save $10 by getting the PSU and HDD that nakedhand listed from this combo link:
$150 - Corsair 650TX 650W PSU + Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive Combo
Oh and some case recommendations:
URL=http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058]$60[/URL] - NZXT M59 ATX Case
$70 - Lian Li Lancool PC-K56 ATX Case
$70 - Cooler Master RC-590-KKN1-GP ATX Case
$70 - Cooler Master CM690 II Basic ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$90 - Lian Li PC-7B Plus II ATX Case
$105 - Fractal Design Define R3 Black ATX Case
$105 - Fractal Design Define R3 Titanium ATX Case
$105 - Fractal Design Define R3 Silver ATX Case
$100 - Lian Li Lancool PC-K7B ATX Case
$110 - Lian Li PC-7FN ATX Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$135 - Antec P183 ATX Case
$160 - Corsair Graphite Series 600T ATX Case
$160 - Silverstone RV02B-W ATX case
$170 - Cooler Master ATCS 840 RC-840-KKN1-GP Full Tower ATX Case
$180 - Cooler Master Cosmos S 1000 RC-1100-KSN1-GP Full Tower ATX Case
$200 - Lian Li PC-B25F ATX Case
$240 - Silverstone FT02B-W ATX Case
$220 - Lian Li PC-A71F Black ATX Case
$270 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
$330 - Silverstone Temjin SST-TJ07B Full Tower ATX Case
Touché! Didnt see that, nice. And I totally agree on open box for a client, not great.
Ya I noticed that and I just found the same board, none open box, but I am still researching tell the client says for sure to go ahead and order aka he gives me the $1500 :p
Thanks again guys
