1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etcGaming, Photo & 2d
2) What's your budget? Are tax and shipping included? 1500 pc
3) Where do you live?new jersey
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.everything
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model.n/a
6) Will you be overclocking?i'd like to, but concerned about heat
7) What size monitor do you have or plan to have?22
8) When do you plan on building/buying the PC?before xmas
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.strong gfx performance, upgrade capability to 45nm core 2 extreme qx9770, not interested in SLI'ing, plan to upgrade RAM to 8 gb, upgrade GPU later, so I upped the watts
Here is my second attempt at a build: $1500. Are the parts compatible? Are the companies/parts reliable? Will this work? Tweaks/Suggestions ae welcome to boost GFX performance, but staying in budget? Any Pros / Cons?
SAMSUNG 22X DVD Burner Black SATA Model SH-S223F $24.99
COOLER MASTER Centurion 5 CAC-T05-UB Black /Blue Computer Case $49.99
ASUS Striker II Formula ATX Intel Motherboard $269.99
EVGA GeForce GTX 260 Core 216 Superclocked Edition 896-P3-1267-AR Video Card $244.99
SAMSUNG Spinpoint F1 750GB 3.5" SATA 3.0Gb/s Hard Drive $79.99
Acer X223Wbd Black 22" 5ms Widescreen LCD Monitor $164.99
Logitech MX518 2-Tone Wired Optical Gaming-Grade Mouse $39.99
Logitech Black Access Keyboard 600 $24.99
Combo
Intel Core 2 Quad Q6600 2.4GHz LGA 775 Quad-Core Processor
Rosewill RX850-D-B 850W Power Supply $298.98
Combo
Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory $174.98
Grand Total: $1,373.88 ($1507.63 w tx/sh)
Thanks
Combo
Combo
Thanks
