Play current and upcoming games at 1080p, 60 fps, photo editing, video rendering.
$1000-$1500, all included (monitor and OS required)
Cleveland, OH, USA
Motherboard
PSU
Case
CPU
GPU
SSD
HDD
Optical Drive
Memory
CPU Cooler
Monitor
None
6) Will you be overclocking?
Quite possibly
7) 7) What is the max resolution of your monitor? What size is it?
1080p most likely
Next month or August
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Crossfire support, USB 3.0, good audio options
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Planning to purchase Win7 64-bit with the system
I need recommendations on my motherboard, case (I want a full ATX tower with fans and space galore), PSU, GPU manucfacturer, and SSD. My current list of parts is below:
CPU: Intel Core i5-4670K Haswell 3.4GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I54670K
MOBO: ASUS Z87-PLUS LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
PSU: SeaSonic SS-750KM3 750W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
GPU: SAPPHIRE Vapor-X 100352VXSR Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: NZXT Phantom PHAN-001WT White Steel / Plastic Enthusiast ATX Full Tower Computer Case
HDD: Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
SSD: SAMSUNG 840 Pro Series MZ-7PD128BW 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
Along with Win7, a cheap CPU cooler, RAM, and a good monitor this looks like it will come out to maybe $1500 buying between Newegg and Microcenter. The PSU is high wattage for the option of going crossfire later or adding a bunch of drives down the road. Any suggestions for things I've omitted or things that should be changed would be appreciated.
Cleveland, OH, USA
Motherboard
PSU
Case
CPU
GPU
SSD
HDD
Optical Drive
Memory
CPU Cooler
Monitor
None
Quite possibly
1080p most likely
