$1500 Build - Help for a Friend
Cmustang87
Gaming/Web Browsing/General Use. He's not interested in Photoshop or anything like that.
$1500 - Shipped
48420, USA
The case and everything in it. CPU, PSU, RAM, HDD (SSD), Mobo, CPU. The parts are being shipped to his parents place over Christmas. He's going to get keyboard, monitor, mouse and headphones when he gets back.
N/A
6) Will you be overclocking?
He says he won't right away, but this will be his first custom build PC. He said he would want to after he's comfortable with it. I told him how easy the new Intel's are to overclock.
1920x1080
Today, if possible.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
He doesn't use any of that, if anything I say he will need SATAIII for a good SSD.
He will need an OS, Win 7 HP 64 bit would work.
These are some notes of mine:
He will be playing: Battlefield 3, TESV: Skyrim are the 2 major ones. He will also be playing others like Diablo 3, Torchlight. He's also in the US National Guard, so if he can get a military discount somewhere that would be great.
I'm between these motherboards - MSI P67A-GD53, MSI P67A-G43, Gigabyte GA-P67A-UD3, and Gigabyte GA-P67A-UD3.
I want him to have an SSD in this build if possible. Crucial or Intel.
I would like to stick with Corsair/Seasonic/Antec for a PSU, I trust them and have had great luck.
He doesn't want a flashy case, he's a pretty simple guy. He likes clean lines/dark colors (Black).
I think whether we got Nvidia or ATI and are able to squeeze in crossfire/SLI support will determine motherboard.
He says he wants the i7 2600 and/or k-version, but I'm not sure if he needs that much.
Let me know if you need any more information, I should be able to provide.
EDIT: Formatting and updating some answers.
Hi!
Perfect. Love spec'ing these kinds of systems. I'm building the newegg cart now -- will post it in a few :)
Out of the mobos you listed, I recommend the MSI P67A-GD53. CPU wise, for gaming, there's little to no real world difference between the i7 2600K and i5 2500K. So stick with the 2500K.
$225 - Intel Core i5-2500K CPU
$130 - MSI P67A-GD53 Intel P67 ATX Motherboard
$30 - G.Skill Ripjaws Series F3-12800CL9D-8GBRL 2 x 4GB DDR3 1600 RAM
$290 - eVGA 012-P3-2066-KR GeForce GTX 560 Ti 448 Cores FTW 1280MB PCI-E Video Card
$110 - Crucial M4 CT064M4SSD2 2.5" 64GB SSD
$136 - Hitachi Desktar 7K1000.D HDS721010DLE630 1TB SATA 6.0Gb/s Hard Drive
$105 - Corsair 750TX V2 750W PSU
Total: $1026 plus tax and shipping
Case wise, have yourself or your friend choose the case. I recommend the following:
$61 - Cooler Master CM690 II Advance nVidia Edition ATX Case
$70 - Lian Li Lancool PC-K58 ATX Case
$70 - Lian Li Lancool PC-K56 ATX Case
$80 - Lian Li Lancool PC-K58W ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$98 - Cooler Master CM690 II Advance ATX Case
$90 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$100 - Corsair Carbide Series 400R ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$120 - Lian Li PC-9F ATX Case
$120 - Fractal Design Define R3 Arctic White ATX Case
$120 - Fractal Design Define R3 Silver Arrow ATX Case
$133 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$137 - Antec P280 ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
$143 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$144 - Silverstone RV03B-W ATX case
$150 - Corsair Graphite Series 600TM ATX Case
$160 - Silverstone RV02B-W ATX case
$164 - Corsair Special Edition White Graphite Series 600T ATX Case
$178 - Silverstone RV02B-EW ATX case
$190 - Corsair Obsidian Series 650D ATX Case
$230 - Silverstone FT02B ATX Case
$270 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
If your friend still want to spend the leftover cash, go for a second set of that 8GB RAM set and up the SSD to the 128GB version. Or even grab a second GTX 560 Ti 448 Core.
Thanks Danny for your recommendations Any reason to not just go up to an ATI 6970 or a GTX 570/580 rather than another 560?
I think the 128GB SSD will be the one that goes in. Thanks agian.
Going out for a little bit, I will be back later to answer more questions.
Well definitely not the GTX 570 as the GTX 560 Ti 448 Core provides 97% of the performance but at 85% of the cost. So the GTX 570 is a poor buy for the money from that perspective.
As for the HD 6970 2GB, my main issue with that is that right now Skyrim and BF3 don't exactly work 100% well with AMD GPUs. AMD and DICE have slowly been improving the performance with AMD GPUs so there's that. But if your friend doesn't want to wait for the improvements, then a Nvidia GPU is your best bet.
I only recommend the GTX 580 if you're going for a balls to walls build.
Thanks. He's going to be building it, he just needed some help piecing it together.
