15+ drive storage system using addonics products?
theinv
Has anyone here tried addonics products?
It looks like they have all the parts needed to build a flexible storage system.
For example, you can build a 15 drive tower using
-- 1 x storage tower IX http://www.addonics.com/products/raid_system/st_series.asp
-- 3 x 5 port sata multipler http://www.addonics.com/products/host_controller/AD5HPMSXA.asp
-- 3 x 5-in-3 disk array http://www.addonics.com/products/raid_system/ae4rcs35nsa.asp
And here are some sample configurations
parts:
addonics storage tower IX ( 9 x 5.25 bay)
5 port hardware SATA port multiplier
Disc array
Problem is, at $99 a pop the port multiplers are not cost effective.
You're better off getting a SAS expander for $200-300, which can connect to more drives and uses a sturdy lockable mini-SAS connector instead of multiple flimsy eSATA cables that can dislodge and kill your array. Plus, performance on the SAS expander will be better. You'll have to pay a bit more for a SAS raid card and cabling.
I used to use port multipliers but I since upgraded to SAS and the performance is much better. On the port multiplier I could never go beyond about 120MB/sec but on SAS expander I can get around 300-400MB/sec.
Do you mean these SAS expanders? They are very expensive.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=sas+expander&x=0&y=0
Also, it is hard to find SAS hard drives
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010150014%201035917796&name=Serial%20Attached%20SCSI%20%28SAS%29
Ok, you definitely missed alamone's entire recommendation. Ok he's recommending that you use a controller card that uses SAS expanders which allows you to use multiple SATA drives. Like for example this card from your link:
http://www.newegg.com/Product/Produ...085&cm_re=sas_expander-_-16-103-085-_-Product
Note the red cable. That's a SAS to SATA cable or SAS expander (IIRC) that lets you use multiple drives off one cable/port. Similar to the port multipliers but SAS expanders offers significantly greater performance. You also don't need to use SAS drives either.
Here's a list of controller cards/SAS expanders:
http://www.newegg.com/Product/Produ...ption=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
