Napoleon
- Jan 27, 2003
Sorry to double post, but just ordered an X5670, hope it works! A plus would be to match/exceed my current 4.2ghz
What OC did you stabilize at? How has your experience been?
I'm running an i7 950 @ 4.2GHZ on an X58A-UD3R rev2 and am thinking about buying an X5670 on Ebay, would you recommend it?
It seems all these Xeon OC's are based on FSB, is the memory multplier locked or can you still keep it at 8x 200 = 1600mhz? I'd like to try for a 4.4ghz xeon OC on my current hardware
drop it back to 191blck and 22 multi and enjoy easy 4.2 bullet proof stable. drop the blck to 183 if you want to use 24 multiJust got my X5670 today and started overclocking it. So far I've been able to get it up to 4680 (195 x 24 at 1.35 vt) Temps are maxing out around 65C, but it keeps BSOD or freezing up. May have to dial it back a bit.
Lots of great info here about overclocking Xeons.
that may be but overheating is not his current problem....he needs to get it stable. He should use turbo and go for a lower blck on that board1.35V is a shitload for that clock speed. Can you do 20x200 at 1.25V?
yea of course.....it a hole lot of trial an error all over againHonestly if he just swapped out the i7 and went with it I would start fresh and work up from the bottom again. What the Xeon likes might be much different than a 45nm bloomfield.
Ok. I'll turn on turbo and turn down the BLCK and vcore. I'm not sure where to start with the other voltages, I may either leave them or set to AUTO
With turbo on, should I turn on any of the power saving features? I'm not sure how clock scaling works with the TURBO function (or when TURBO turns on)
It looks like there is a +2 multiplier for 3 to 6 cores and +3 multiplier for 1 or 2 cores.
I'm not sure how far back to drop the blck to start, perhaps 180?
22x180=3960
24x180=4320 (3-6 cores)
24x180=4500 (1-2 cores)
all i know is blck limitations is what typically make the overclocks more difficult. I also seem to remember people with certain board when switching to hexa cores all of a sudden having trouble reaching blcks they easily hit with quads....If your one of those then use the turbo by all means. The way you described turbo seems correct to me, but it varies slightly with different bios and boards so it will be different for some. 180 blck sounds like an ok starting point to me.....if its not stable back up so more![]()
I just finished 8 hours prime blend at 175x24 (turbo enabled, multi set to 24 in bios)
HWmonitor: hwmonitor_x5670_42_8hrprime.jpg
One thing that is concerning is the large variance of my voltage lines; does HWmonitor typically read badly or can I realiably blame this on my PSU?
- 3.3V - 3.136-3.248
- 5V - 4.758-4.919
- 12v - 12.288-12.416
cpu voltage 1.35
pll voltage 1.9
qpi/dram 1.35
dram 1.65
all spread spec disabled
dram speed 1531
qpi link 6893
overclock xmp
dram time all default
i use highest multi for me 22
speedstep disabled
c-states all on
blck 191
I recently went from a Corsair TX 850w to a EVGA 750P2 and noticed my voltages show practically no variances now.
i get the hole try everything approach your doing but 4.2 should be very easy to do, but you appear to be focused on 4.4-4.5ghz.....that where it gets difficult . Those rampages don't seem to need the the higher pll voltages from what i remember.....but it does help these p6t models....
cpu voltage 1.35
pll voltage default
qpi/dram 1.35
dram 1.65 or what ever yours is rated for
dram speed 1531
qpi link 6893
overclock xmp
multi 22
speedstep disabled usually
c-states all on (doesn't hurt a thing)
blck 191
I would be amazed if this wasn't bullet proof stable right of the get go for you. higher clocks between 4.2-4.6 should just be a matter of slightly higher vcore but getting 4.4 or higher stable just isn't meant to be for every cpu....it either is or isn't really (most are not)
4.2 or below is pretty much guaranteed
actually its almost always easier to do with less voltage at lower blcks....since your board can lock in the 24 multi unlike mine go ahead and use it with a lower blck 175 to get 4.2 with even less voltage
What blck and multi did you settle on? Same as your previous quad?I tried auto without much success. While I can boot into windows at 4.3/4.4, it doesn't want to be stable.
Vcore: 1.20625 + 0.15 (reads as 1.344 in HWmonitor)
CPU PLL: 1.86
QPI/Vtt: 1.335
VDIMM: 1.66 (reads as 1.648 in HWmonitor)
QPI PLL: 1.16
IOH Core: 1.16
ICH I/O: 1.5
CPU Clock drive - 700mv
PCI Expres Clock Drive - 700mv
Ram multi: 10x
Uncore multi: 15x
QPI Link - 36x
Seems I'm stable at 4.2ghz, I'm happy where I'm at. I will try again when I get a new PSU/memory.
My CPU mark score is 10,769 which I'm pretty happy with, based on their comparison just a tad under core i7-6700k@4ghz - CPU marks core 11004 PassMark Software - Display Baseline ID# 618181
My FPS in CPU dominated games like Starcraft2 and Heroes of the Storm has improved vs the [email protected]. I think this will be a good setup when I get a new GPU
Well I got my X5670 in, a quick and dirty 200x21 with 1.250V got me up and running. Interesting IMC on this chip, it will not do 1600mhz DDR3 if the FSB is 133 but it does it just fine at 150/166/191/200. The i7-920 had no issues with 1600mhz at 133 FSB on this Rampage III Gene.
And of course now I realize I have Windows installed under IDE mode.
Have my played with your OC/voltaged since this upgrade? Have your temps changed? Stability changed?
You running win 10?
Do any of you guys run mixed RAM setups? I'm waiting on a new kit of memory to come in for my board but I figured I would just play with what I have on hand and see how it runs, and what I have now is 2x4GB, 2x2GB, and 3x1GB. So I went ahead and put both 4GB on A1/B1, both 2GB on A2/B2 and two of the 1GB on A3/B3 for 14GB total. It seems to be running fine in triple-channel mode since the amounts are balanced, and I haven't noted any stability issues at 1600mhz.
You can mix ram size. What happens is: The MB will take the smallest stick of ram and every other stick will run with it in triple channel.
The rest of the memory will be in single channel mode.
Say you have two 2gb and one 4gb, you will have 8gb total. 6gb will be in triple channel and the other 2gb will be in single channel.
Say you have two 4gb and one 2gb you will have 10gb total. 6gb will be in triple channel and the other 4gb will be in single channel.
The triple channel will be used first
fuck win 7 and all those pesky windows updates...clean win 10 install takes all of 5 min![]()
This is the same experience i had.I know it can do it and it will run but stability was my concern. The X5670 will not run those 14GB stable like that while the i7-920 will. Seems like my i7 had a much stronger IMC.
Win 10 is fine if you don't mind MS having access to all your data.
