Man I think you are right after, watching this video , I didnt really know much about case air flow. And that is probably a huge reason why I am getting the high temps on my overclocks.i hope you been leaving the case side off all this time......you have zero airflow lol. I like the idea of the inverted case in theoy....but everywhere i look to install a rad in the case is all cramped up....hmmm....like the opposite of aio cooling friendly. i might try to pull in air from the bottom somehow and cut all the shit out of the way in the front of the case and put the 240mm rad there blowing out instead of in.....if you try to blow in all that hot air will be fed straight to the vc cooler. fuck that case sucks for what we need to do. How big is the area in front of the power supply? might be wide enough for a single fan rad? need to measure and see cause that would be the least amount of bullshit modding. It seems with all tha unused space a rad would be best in the front....see if there room to do with out cutting or with as little work cutting....sometimes you can remove stuff that that in the way.....youl have to see if you can open the bottom front up?
Those brackets in front look removable...are they?
Holy cow thats a lot of stuff for 60 bucks......Im usually eyeballing the fancy cases [H] reviews like the Case area....Some really nice stuff they look at....hell we all know perople who spend 60 bucks on a couple fans and an adapter lol....So for the money its little PLAIN but looks awesome to fit all your shit inside..and heck the no window is 48 bucksGood airflow is very important.
I like the DIYPC D480 for the price, it comes with a good fan setup by default, five seemingly decent fans, and it has a two speed fan controller. You can also fit a 280mm radiator in the front and a 240mm radiator on the top.
With that setup, I would probably get a 240mm for the top, have the GPU rad in the back and leave the front fans in place so you aren't blowing hot air over your board/hard drives.
Great, I've heard good things about that case too. Good luck!that does look good and cheap, but I just went with this Amazon.com: Phanteks Enthoo Pro Full Tower Chassis PH-ES614P_WT White: Computers & Accessories
Yep, it works well. I use it for my server, and have built a few machines for friends using it.Holy cow thats a lot of stuff for 60 bucks......Im usually eyeballing the fancy cases [H] reviews like the Case area....Some really nice stuff they look at....hell we all know perople who spend 60 bucks on a couple fans and an adapter lol....So for the money its little PLAIN but looks awesome to fit all your shit inside..and heck the no window is 48 bucks
I really like this case...just keep in mind thats a FULL tower...I usually get MIDS myself so just be aware of the sizethat does look good and cheap, but I just went with this Amazon.com: Phanteks Enthoo Pro Full Tower Chassis PH-ES614P_WT White: Computers & Accessories
tbobb..Can one of those cases fit those dual socket boards? NM im broke
Phanteks Enthoo Introduction - Phanteks Enthoo EVOLV ATX Mid Tower Chassis Review
Fractal Design Define S Exterior - Fractal Design Define S Window Mid-Tower Chassis
Are both extremely impressive according to [H] reviews......read them before your committed on the case you picked out is all i recommend .
I wouldn't have recommended a D15 for 1366 because of the hassle to get the mounting kit. You'll need to send them proof of purchase for the cooler and a 1366 board, then it'll take up to two weeks to get it.I went ahead and got the noctua NH-D15 cooler instead of an AIO. Cheaper and seems to get same temps as an h100i from what I have read.
that is fine with me, I put in a request last night and got a confirmation email this morning "thanks for choosing a Noctua product and for your interest in our NM-I3 kit.
The requested parts will go out today, please expect a delivery time of 10-18 working days"
I doubt it would very well with six core chips, it looks like it only has four phases. Even if a six core would work, it would probably work poorly. And dual channel? Why?!So I noticed on Ebay recently some unbranded x58 boards have shown up from china. They only have 2 ram slots and no real information can be found on them. I was curious if anyone has tried one? In the picture I can see ZX-x58 written on the board. If these could use the cheap 6 core xeons at about 80-100 bucks including shipping might be worth a gamble.
I just scored another 1366 rig off of CL, found this one and got it for $60. MSI X58 Pro-E, 6GB DDR3 1600, MSI HD6670, 500GB HDD and Windows Vista, 7, and 10 disks. It was a cyberpower prebuilt, never been overclocked. Time to pick up a new hex off of Ebay and see if the board will work with it. Supposedly the latest BIOS will run the 6-cores.
Took the pic after I started taking it apart so I can clean it up and put it in a better case.
This should be what to expect on build day...Only problem i see is that back rad for the video card he has will be a little crowded for room. Perhaps the cpu cooler can be mounted to point up. Now if the video card cooler can reach the top it still might work out...but i dont know if it would reach the top in a full tower? This is why i said careful research is needed when picking parts. Worst case scenario i guess the vc rad can be mounted on the outside of the case in the back. Honestly im not sure about that. Actually it might reach the front or the bottom as well?
this cooler choice in itself should look good anyway
When I received my P6T6 I had some very strange issues, it would randomly reboot, some of the fan headers wouldn't work and sometimes I wouldn't get any signal on first power on. I was stumped.Ok looks like removing the cmos battery completely fixes the problem. Will verify tomorrow, not sure if battery just died
Another X5670 is officially dead, added to the pile of dead xeon's (which now stands at a grand total of 4).
I pulled my R3E from my water cooled box and absent mindedly left the BIOS alone, gave the system to someone to build in to a new box, he strapped a heatsink to it but it must have cooked pretty quick at 4.4Ghz on air with the amount of volts I had cranking through it. I bought a second hand i7 960 for $90 locally just to make sure it wasn't the board, and thankfully it works.
Not really a big deal but still a little sad that I can't pass on a 6 core to the recipient of this machine, I still haven't decided where it's going. The irony is, I have an H110 that was meant for this system but the box doesn't have space to mount it.
I'm surprised that you managed to kill so many chips.
Check the first page, you won't be surprised.
If im not mistaken MOST if not all his chips were delidded (I believe) and begs the question if that played any role on what happened. It could have been some kind of failure on the board itself as im sure (sending higher voltage than whats reported?) could definitely do that.....That Depends on if they all died on the same exact board. I can see how where mine used to be about 90% stable at 4400mhz (never 100%)...these days when i test it at that clock it fails every time. Gives me the impression these chips sorta breakdown over time.
Haha, your an adventerous soul. I thank you for your sacrifices so that the community can learn from your testing.
PS: I really hope your not as curious to muck around with your 5960x. Killing a $150 chips is bad enough, but a $1200 chip would be a real kick in the pants.
