- Mar 18, 2004
Hi Guys,
I'm putting my loop together and to make a run real short from the outlet on rad to res, I need a 135 degree bend. The rad and res are pointing in opposite directions basically. If I put 3 45 degree bitspower single rotaries in series, it creates a 135 bend that makes the connecting tube pretty much a straight run. Any issue to putting 3 of them in series? It is a loop that only has the cpu on it going through a 120.3 rad. Pump is a laing 3.25 18w through an apogee XT block. Any help would be appreciated. Thanks.
