- Jan 3, 2009
maybe it's child proof?
From the article, the features that you don't find in normal Blu-Ray players are:
1. precision spring-loaded legs
To prevent them from skipping? Do Blu-Ray players ever skip?
2. a completely isolated power supply
Isolated from what?
3. Goldmund Magnetic Damping
What does magnetics have to do with an optical reader?
Since they're digital, how does a $135,000 Blu-Ray player reproduce sound or video better than a $135 Blu-Ray player?
1 & 3: to keep the disc from vibrating, thus reducing jitter. Usually jitter is not consciously audible (as stated in that article) but it is present constantly with optical discs. Less jitter = better sound (and it is measurable).
2: isolated from the rest of the circuitry to reduce EMI (and possibly RFI). It's also probably isolated from the chassis to reduce vibration from the transformer (their site wasn't specific about that but I figure if they're going to these lengths...).
This is all fine and dandy, but if you took the DAC out of this and put it in a 'normal' chassis would it sound any different? Probably not to a noticeable extent, but I bet it would reduce listener fatigue (albeit probably by a very small amount). As for the claims of this giving you a better picture, I'm highly skeptical.
Worth the money? Hell no! Not even if I had $100M in the bank. These really aren't meant to be sold anyway as they are a reference design (they're only making 50 of them).
Wouldn't all digital players have the same output?
(quality of the output video card depending).
Most DVD, and pretty much all BluRay players have a small amount of memory onboard to perform buffering. Jitter is eliminated as a result.
does it play crysis? >>
You are welcome to believe whatever you want to believe. Just don't try to pass it on as a fact.
I heard yellow network cables has less jitter than blue ones.![]()
considering it plays SACD's im going to guess theres an oppo BR player in there... thats the only player (besides certain PS3's) that im aware of that plays both BR disks and SACDs
Will it blend?
http://www.blu-raydisc.com/Assets/Downloadablefile/BD-ROMwhitepaper20070308-15270.pdf See the part about jitter? They have measurements. You can't measure something that doesn't exist.
I'd pay to see someone blend one of these. More accurately, I'd pay to see the reaction on the face of people who would consider buying one of these when someone blends one.
I just don't get this stuff. None of this crap ever does better-than-odds in blind tests.
$135,000 bluray player and they put a cheap ass readout screen on it.![]()
You guys just don't understand the quality of true craftsmanship.
What makes this unit better than the average run of the mill BD player is this simple fact. Average BD players are only manufactured through a speedy child sweat shop process that lacks much quality assurance where this BD Player has the sweat of a thousand little Chinese children behind each square inch of it's being...
Obviously you guys just aren't sophisticated enough to see true quality even when it is right in front of your very own eyes!
rofl. $135,000 worth of build quality? You have to be joking. I'll bet the laser diode still has an MTBF of 5-7 years.
This player does nothing above and beyond stroking the ego of the ultra wealthy, self-indulgent douchebag dumb enough to buy it. They took steel billets, threw them into a CNC, and used the product of that to create a hulking chassis for a run-of-the-mill BluRay player. Is that *really* worth $150k? No.. It looks like about $600 in metal stock, a few simple lathe operations, and a few mill ops.
If it comes on sale for 99% off, then at $1,350, it *might* be a good deal.![]()
